Wiring harness
andrewMcF
- Crank Case
Wiring harness
Looking for a good place to purchase a wiring harness for my 67 109 or a good article (with pretty pictures) on how to build one. What's a wire harness worth these days anyways? None of the usual suspects have them on there website catalogs...
I personally hate messy wiring but unfortunately lack the anal retentiveness and know how to do it right
Andrew,
You are already considering purchasing a complete harness and I would advise that you continue that quest. Unless you are wanting to make numerous custom modifications to the vehicle I think that you will find it much more economical to buy a ready made harness. I wired my own 88" years ago and while the job turned out very well (in my opinion) it was a whole lot of work (to do it 'right') and very expensive if you are buying all the materials retail. Unfortunately I can;t be much help in advising on a source but I know they are out there.
Regards
Regards
- Washed Up
Check with Alan first, but if he can't help order one up from AUTOSPARKS in the UK.
http://www.autosparks.co.uk/index.php?cPath=59
I have no experience with them but here is a company on this side of the pond
http://www.britishwiring.com/
