Wanted fan for 99 land rover 4.0ltr v8
Forum rules
Tahltan
Wanted fan for 99 4.0ltr v8
Does anyone have a idea on what is the issue
Fan belt was running fan breaking it in several places
We're belt didn't break but was breaking up
She's a reliable and never to many issues
I truly appreciate any responses
Happy New Year
Or if there's any reliable mechanics also
B glad to pay
Happy New Year
B glad to pay
Re: Wanted fan for 99 land rover 4.0ltr v8
Hi,
Just to confirm is it the plastic fan blades that are broken? Is your fan loose at the center nut, have you grabbed it and tried to wiggle the fan to see if there is any play? They are a left hand thread so don't normally come loose unless not put back on properly.
If the fan is not loose then something else went into the fan blades. You said the fan belt started to strip so this could of got caught around the fan blades?
How is your coolant level? Are you loosing any?
-Andy
PS - there are Discovery's and Range Rovers (P38) at most of the breaker yards so you may want to start there for another one.
Otherwise pick up a new one from Rovalution or Hesp on the North Shore.
-Andy
Tony4921
I have several fans. I can send one over on Greyhound. Do you need the viscous coupling with it?
Tahltan
Fans not loose fluids and oil are good also it looks like the fan belt came of 50 percent of the way
Tahltan
Yes thank you appreciate this
Could u call me at 604-816-2403
Tony4921
$100 for the fan & coupling
Tahltan
Yep no problem thank you
I emailed u with my contact info
Once you get the new belt and fan installed I would check your belt alignment just to confirm visually that its all nicely aligned on the various pulleys.
Hopefully it was just a case of old belt failing and when it came off it contacted the fan blades? Pretty unusual though, especially if it only came 50% off.....
Tony4921
I didn't get an email with your info.
Tahltan
Darn thought i sent it properly guess not
I'm not that good with all this kinda stuff
Could u text me at
604-816-2403 or email me at
[email protected]
Have a good day
Could u text me at
[email protected]
Have a good day
