1958 Series 1 88" "red&red"
jacobko
Crank Case
Re: 1958 Series 1 88" "red&red"
#26 Post by jacobko » Tue Jul 05, 2022 4:28 pm
More axle work!
Rear axle: I was able to find replacement rear diff in my basement for the one with bad bearings that I installed a few weeks ago. It is now in. I've decided to go with a fully floating rear axle on this one. I've heard a few stories of semi floating shafts on series I flying out while driving, and I don't really want to experience that. More to come on the fully floating conversion! I will be keeping the original Series I axle (and narrower track width vs. Series 2/3)
Front Axle: Original Land Rover swivel balls, and good quality bearings, seals, and brakes. Nothing too special here except that I "upgraded" the steering to a later Railko bush setup.
Looking good now sitting on it's two front feet for the first time in 30 years.
(310.42 KiB) Downloaded 690 times
(298.56 KiB) Downloaded 695 times
(292.5 KiB) Downloaded 690 times
(161.58 KiB) Downloaded 694 times
(306.91 KiB) Downloaded 686 times
jacobko
Crank Case
#27 Post by jacobko » Tue Jul 05, 2022 4:33 pm
Engine Time!
Now that the front axle is in I thought I should clean the dust off the engine and put it in. This engine was rebuilt many years ago by Gary Mummery, but has been collecting dust ever since. I gave it a new thermostat, and bypass hose before putting it in. I'll probably have to do a few more little things to it, but all accessible while it is in the engine bay. It now has a home. I quickly assembled a few body panels just to see what things will look like when I'm done.
(329.97 KiB) Downloaded 690 times
(257.5 KiB) Downloaded 691 times
#28 Post by ANDYD » Wed Jul 06, 2022 10:30 pm
Looking good! Thanks for the updates.... your photos are bringing back my memories of my S1 rebuild a couple of years ago!
jacobko
Crank Case
#29 Post by jacobko » Thu Jul 07, 2022 9:35 am
ANDYD wrote: Wed Jul 06, 2022 10:30 pm Looking good! Thanks for the updates.... your photos are bringing back my memories of my S1 rebuild a couple of years ago!
Thanks ANDYD! I had a good look through your build posts on here, and they have helped in a few areas. Especially with removing the old brake/clutch pivot from the frame.
jacobko
Crank Case
#30 Post by jacobko » Mon Oct 03, 2022 4:31 pm
I'm back! Over the past couple of months I have been busy getting married and winding down here on the farm. On to more Series I project stuff over the winter now. I decided to bite the bullet and get started on the transmission that has been sitting on the floor of my garage since the start of the year. I was able to open it up and get the parts sorted and cleaned (somewhat). I definitely will be replacing all of the bearings, seals, and some of the gears. Overall though the transmission looks like it is in pretty good shape. It was definitely rebuilt poorly in the past at some point, but I've found no major damage (yet). My next task over the next couple of weeks is looking through each part in detail and figuring out if it is reusable or not.
Here are some before and after shots of the disassembly.
(141.94 KiB) Downloaded 611 times
(115.27 KiB) Downloaded 605 times
(98.24 KiB) Downloaded 609 times
jacobko
Crank Case
#31 Post by jacobko » Tue Oct 11, 2022 8:57 pm
Well the hard part is done. Parts cleaned, sorted, and assessed. I’ll be posting a full list of all the parts that I need to order for this particular rebuild. Some people have asked about cost in the past, so I’ll post that too.
(554.92 KiB) Downloaded 595 times
(534.65 KiB) Downloaded 590 times
#32 Post by ANDYD » Thu Oct 27, 2022 1:17 pm
Nice job, I'm impressed with your level of strip down, nothing quite as nice as starting with a clean canvas to show your true artistic skills on the rebuild.
Keep up the good work 8)
-Andy
PS- Congrats on getting married - let's hope she understands that there is two loves in your life .... and the Land Rover will demand as much attention (or more) :wink:
jacobko
Crank Case
#33 Post by jacobko » Fri Oct 28, 2022 12:39 pm
Thanks ANDYD!
I got some gears delivered today in the form of a 1959 Series II! The gears in my transmission were pretty shot, and this one looks like it has some nice gears in it (in the transfer case at least). Looking forward to popping open the gearbox and seeing what's in there.
(376.06 KiB) Downloaded 522 times
jacobko
Crank Case
#34 Post by jacobko » Mon Oct 31, 2022 10:44 am
Well, the big day has arrived! I've ordered everything needed for the transmission rebuild. See the table below for all the details. After shipping, taxes, and conversion to CAD we are looking at $2,969.26.
DescriptionPart NumberQTY$ Per UnitLine Total
Bolt 1/4 BSF x 5/8 Inch 2506932506931£0.28£0.28
Nut 2BA Genuine 2247 3823 RTC608 GRTC608 G2£0.20£0.40
Ball Bearing for Steering Box & Gearbox Genuine 1643 BLS112L GBLS112L G3£0.18£0.54
Selector Detent Spring for Forward Gears Genuine 3649 G3649 G2£0.35£0.70
Rubber Grommet for Selector Springs 585258522£0.20£0.40
Sealing Ring for Selector Shaft Genuine 272596 241596 G241596 G2£0.30£0.60
Selector Shaft Seal Reverse TRS1114L 2725972725971£0.29£0.29
Nut for Halfshaft 10 Spline 325932591£0.75£0.75
Split Pin Various Apps. 2428 PS608101PS6081012£0.12£0.24
Grub Screw for Gear Lever 237423 5074475074471£1.25£1.25
Spring for Reverse Gate Genuine 514650 231116 G514650 G2£0.39£0.78
Reverse Hinge Adjustment Screw Genuine 76653 G76653 G1£0.18£0.18
Spring for Gear Lever Housing Genuine 219723 G219723 G1£0.58£0.58
Circlip Gear Lever Genuine 219797 G219797 G1£1.00£1.00
Lock Tab for Gear Lever Housing Genuine 2499 G2499 G4£0.32£1.28
Gasket for Clutch Shaft Cover Plate Genuine 213662 G213662 G1£0.68£0.68
Bearing Output Shaft & Clutch Release Genuine NTN 214797 RTC3406 STC1130 GSTC1130 G1£4.75£4.75
Spring for Transfer Gear Selector Genuine 217445 G217445 G1£0.69£0.69
Oilite Bush for Four Wheel Drive Lever Genuine 230086 G230086 G1£1.24£1.24
Clevis Pin & Spring Genuine 216421 G216421 G1£0.95£0.95
Nut for Hi - Lo Lever NT407041L 376437641£0.38£0.38
Transfer Lever Spring Genuine 243714 G243714 G1£1.92£1.92
Clevis Complete 4 Wheel Drive Rod 1/4 BSF Genuine 215808 G215808 G1£8.75£8.75
Nut 1/4 BSF 2823 381938195£0.10£0.50
4WD Selector Rod 5718555718551£2.40£2.40
Cup for 4 WD Selector Rod Spring 2346582346581£1.60£1.60
Plain Washer 1/4 287628761£0.72£0.72
Copper Washer Axle & Gearbox Drain Plug Genuine 230509 515599 FRC4809 GFRC4809 G3£0.73£2.19
Shim 0.003 Inch for Speedo Pinion Housing Genuine 235455 G235455 G4£1.45£5.80
Seal for Bell Housing Top Cover Oval Genuine 232606 G232606 G1£6.95£6.95
Grommet for Gearbox Clutch Shaft LHD 2362822362821£17.98£17.98
Cork Washer Oil Filler Cap Gearbox Genuine 11932 506706 G506706 G1£1.90£1.90
Washer 3/8 Plain WB110061L 2210221012£0.38£4.56
Nut 3/8 BSF NH406041LNH406041L14£0.11£1.54
Lock Washer Rear Mainshaft Genuine 217476 G217476 G2£0.47£0.94
Distance Piece Rear of Mainshaft Genuine 502482 G502482 G1£8.25£8.25
Mainshaft Centre Bearing Genuine 1645 G1645 G1£11.95£11.95
Circlip Mainshaft Bearing Housing Genuine 9960 G9960 G1£0.95£0.95
Peg for Mainshaft RTC1979 9561RTC19791£0.25£0.25
Thrust Washer for 3rd Speed 0.125 Inch Genuine 8188 RTC1962 GRTC1962 G1£3.90£3.90
Thrust Washer 0.135 Inch for 3rd Speed Genuine 231737 G231737 G1£6.95£6.95
Mainshaft Snap Ring RTC1957 640264025£0.98£4.90
Thrust Washer 0.128 Inch Genuine 267573 G267573 G1£3.95£3.95
Thrust Washer 2nd Gear 0.135 Inch Genuine 267575 G267575 G1£6.85£6.85
Needle Roller Bearing for Mainshaft Steel Cage Original Equipment Manufacturer 6397 OEM6397 OEM1£9.95£9.95
3rd Speed Layshaft Mainshaft Gear Genuine 245767 G245767 G1£139.95£139.95
Locking Washer Primary Pinion Genuine 8250 RTC1963 GRTC1963 G2£3.30£6.60
Bush for Reverse Gear Genuine 561954 G561954 G1£16.35£16.35
Layshaft Rear Bearing Genuine RHP 55715 RTC1412 GRTC1412 G1£33.15£33.15
Split Ring 2nd Speed Layshaft Gear Genuine 239272 G239272 G2£2.75£5.50
Lock Tab for Layshaft Genuine RTC1982 9931 G9931 G2£0.50£1.00
Split Pin 298029801£0.12£0.12
O Ring for Speedo Pinion & Rocker Cover 267828 2429882429882£0.30£0.60
High Gear Wheel Mainshaft Genuine GLR7000 218243 G218243 G1£50.95£50.95
Thrust Washer for High Gear Wheel Genuine 90217488 217488 G217488 G1£2.65£2.65
Propshaft Bolt for Gearbox Flange Genuine 90512701 217565 G217565 G4£1.55£6.20
Lock Nut 5/16 BSF Aerotight Genuine 251321 50525 G50525 G10£0.50£5.00
Bolt 5/16 BSF x 7/8 Inch Genuine 217564 G217564 G6£0.27£1.62
Speedo Pinion Oil Seal Genuine 211502 G211502 G1£0.95£0.95
Genuine Locker for Stop on Second Selector Shaft.2102041£0.45£0.45
Detent Spring for Reverse Shaft 1948-84561022£0.72£1.44
Bolt 5/16 x 1 Bsf2371602£0.19£0.38
Genuine Adjustable Stop for Reverse Selector2310331£1.39£1.39
Genuine Locking Plunger for Selector Rods.556382£0.32£0.64
Land Rover Gasket Set Gearbox All 1948-846006031£1.90£1.90
Genuine Bush Transfer Output Shaft. 1951-84.2345341£0.75£0.75
Corteco Land Rover Oil Seal Output Shaft Front and Rear 1948-84FRC1780G2£1.28£2.56
Genuine Dust Cover Plate for Transfer Shafts 1951-19552334681£22.56£22.56
Rubber O Ring for Gear Lever 1954-84FRC13871£0.17£0.17
Locker Gear Lever Gate 1948-79.FRC24691£0.85£0.85
Genuine Seat for Gear Lever 1949-842197211£4.58£4.58
Genuine Spring for Clutch Fork.2648061£2.56£2.56
Genuine Oil Seal for Cross Shaft LHD 1948 532199881£5.80£5.80
Split Pin Various Applications2392L1£0.10£0.10
Star Washer Fixing Transfer Link to Shaft776261£0.15£0.15
Split Pin Tailgate Chain Other Fittings and Selector Lever 4 Speed V83958L2£0.33£0.66
Genuine Spring for Selector Fork Transfer 1951-84.2334492£0.12£0.24
Genuine 4WD Shaft for Transfer Box. 1951-84.2334161£18.67£18.67
Genuine Shim for Speedometer Drive .005 Inch2176221£5.50£5.50
Genuine Shim for Speedometer Drive .010 Inch2176231£5.80£5.80
Genuine Shim for Speedometer Drive .015 Inch2176205£1.30£6.50
Blanking Grommet for Bell Housing2326041£12.30£12.30
Plain Washer 5/8 Od x 5/16 ID V.a. Lr and Range RoverRTC6131£0.26£0.26
Genuine Shim Washer Rear Of Mainshaft 1948-845015011£0.22£0.22
Corteco Oil Seal Gearbox to Transfer Box 1948-84236305G1£4.60£4.60
Genuine Circlip Mainshaft Bearing Housing 1948-84RTC19841£2.35£2.35
Genuine Mainshaft 1951-71.2642501£105.00£105.00
Peg for Mainshaft 1948-8464051£0.25£0.25
Thrust Washer 128 for 3RD Gear Mainshaft.STC11181£3.10£3.10
Thrust Washer Mainshaft50703G1£6.27£6.27
OEM Thrust Washer 125 for 2ND Gear267572G1£7.35£7.35
OEM Thrust Washer 130 for 2ND Gear267574G1£7.35£7.35
OEM Bronze Distance Piece Mainshaft 1954-71571218G1£38.53£38.53
2ND Gear ( Pair ) 1952-642457661£121.09£121.09
Primary Pinion and Gear 1950-64.5184731£125.00£125.00
Genuine Shield Primary Pinion 1948-71.RTC19541£0.85£0.85
OEM Land Rover Bearing for Primary Pinion 1948-8455714G1£34.12£34.12
Genuine Layshaft All Models 1948-63.RTC19811£95.00£95.00
Genuine Distance Piece Front Of Layshaft .312 Inch2416491£6.90£6.90
Genuine Distance Piece Front Of Layshaft .352 Thick2416511£3.95£3.95
Genuine Shim for Intermediate Gear 1948-642348352£3.38£6.76
Genuine Circlip for Front Output Bearing 1948-84 and Front Output Shaft LT95902175261£0.44£0.44
OEM High Gear Bearing for Land Rover S3 Transfer Box Output Shaft217490G1£47.44£47.44
Genuine Circlip for Output Shaft in Transfer BoxCCN1221£0.30£0.30
Genuine Low Gear Wheel 1948-65.2354381£19.45£19.45
Genuine Circlip Output Shaft Rear2175461£5.23£5.23
Special Socket for Mainshaft Nut Series Vehicles6003001£28.00£28.00
Flange for Output Shaft Front.5399931£49.99£49.99
Bearing for Front Output Shaft217325D1£14.76£14.76
Syncro Hub Assembly 3rd/4th GearFRC1758D1£146.70£146.70
First Speed Gear - Layshaft5016161£20.54£20.54
Sleeve Laysaft2638781£4.28£4.28
Bearing Layshaft Front5762071£42.50£42.50
Bearing Output Shaft Rear902175121£22.94£22.94
Mudshield for Output Shaft2360742£5.43£10.86
oldgravy
Captain Crunch
#35 Post by oldgravy » Mon Nov 07, 2022 8:14 pm
I bet that's gonna be a heavy box.
jacobko
Crank Case
#36 Post by jacobko » Tue Nov 08, 2022 11:53 am
The work continues while waiting for gearbox parts! Got the pedals set up, and fuel tank installed. The fuel tank is an amazing thing, from Pangolin 4x4.
(94.15 KiB) Downloaded 467 times
(131.37 KiB) Downloaded 468 times
#37 Post by ANDYD » Sat Nov 12, 2022 10:13 am
All those levers and springs are a marvel of British Engineering !!
Your Fuel tank looks great 8) The Gas stations in Richmond are all Full Service, I have fun pulling in with my Series 1 and telling the young 17yr old attendant "Fill her up" ...
Then watching while they circle the vehicle looking for the gas cap :lol: cruel I know!
mjc_seattle
Apprentice
#38 Post by mjc_seattle » Wed Nov 16, 2022 9:32 am
Pulling into a gas station in rural Oregon one fine winter day, the attendant looked at me kind of funny. Rolling up in a snow-covered 107 Station Wagon was bound to get the looks. In Oregon, at least at the time, you couldn't pump your own gas. The attendant was astonished as I pulled the seat out on the passenger side and opened up the tank. Fill 'er up please. All the while having a black lab look over his shoulder to make sure he did it right. I didn't make him play the "find the filler cap" game. It was too cold, but I still got a good laugh out of it.
Matthew Clark
Seattle, WA
1973 Ser III 88"
jacobko
Crank Case
#39 Post by jacobko » Thu Jan 26, 2023 12:02 pm
Okay, I've fallen behind on the updates again. Before Christmas I was able to finish rebuilding the gearbox! It was super fun to do, and I was able to do it all in my living room. It was too cold to do it in the garage without the heater installed yet!
(103.71 KiB) Downloaded 368 times
(105.7 KiB) Downloaded 363 times
(76.15 KiB) Downloaded 360 times
(112.66 KiB) Downloaded 369 times
(97.85 KiB) Downloaded 362 times
jacobko
Crank Case
#40 Post by jacobko » Thu Jan 26, 2023 12:07 pm
Next step was changing the clutch and installing the gearbox. Still no heater in garage...
(98.76 KiB) Downloaded 360 times
(108.35 KiB) Downloaded 366 times
(100.73 KiB) Downloaded 362 times
jacobko
Crank Case
#41 Post by jacobko » Thu Jan 26, 2023 12:11 pm
Well here it sits today. Gearbox fully installed, finished aligning the doors properly, installed the galvanized sills below the doors, finished wiring the dash, and loosely installed the seatbase. I wanted to tease myself with what things are going to look like on the interior, so I tossed the seats and floors in there to take a pic.
(109.28 KiB) Downloaded 367 times
StuartC
Wing Nut
#42 Post by StuartC » Thu Jan 26, 2023 5:50 pm
Good job!
Looks like there are not too many days before the rubber hits the road.
sckoby
Apprentice
#43 Post by sckoby » Sun Apr 02, 2023 9:20 pm
Hi Jacob, It was great to meet you the other day. I have been on a very long hiatus from my land rover project and with certain things going my way with the paperwork, it has been fun getting back onto the old truck. Aside from the galvanizing work, do you get other parts powder coated, and if so, are they local? What is the name of the company in Calgary that does your galvanizing? It would be good to have you over to see where I'm at and to pick your brains on some things.
Rgerads,
Doug
jacobko
Crank Case
#44 Post by jacobko » Thu May 04, 2023 9:46 pm
Well it’s been just about two years and it’s done! There is so much fiddling that needs to be done right before you think you are almost done. There are a few small things that I would like to get done in the future. Things like reupholstering some seats, maybe installing seatbelts, and wiring the interior dome light, but not super important right now. I just want to get driving! I’ll keep this forum post alive by posting annual maintenance stuff, but other than that maybe I’ll see some of you out on the roads or off the roads!
(212.63 KiB) Downloaded 133 times
RobinS
Over Inflated
#45 Post by RobinS » Fri May 05, 2023 5:52 am
Congratulations on a great job , I would love to see it some time . where are you located
oldgravy
Captain Crunch
#46 Post by oldgravy » Fri May 05, 2023 8:57 am
Fantastic news. Congratulations! A lot of hard work for sure.
jacobko
Crank Case
#47 Post by jacobko » Fri May 05, 2023 11:14 am
Thanks guys! I am located in the Kootenays right between Castlegar and Nelson. If you're in the area give me a shout!
oldgravy
Captain Crunch
#48 Post by oldgravy » Fri May 05, 2023 1:05 pm
jacobko wrote: Fri May 05, 2023 11:14 am I am located in the Kootenays right between Castlegar and Nelson.
Oh man, another Slocan Valley dude...
(I went to high school in Nelson)
#49 Post by bsa_m21 » Fri May 05, 2023 6:01 pm
Great job Jacob. Love that you kept the patina. Makes it perfect. 👏👏
Landy Man
#50 Post by Bill E. » Sat May 06, 2023 6:57 am
Jacob,
Congratulations, a tremendous accomplishment. Respect!!
Bill
