Whipsaw - May Long Weekend
Doc Tari
Re: Whipsaw - May Long Weekend
The snow and scenery were awesome
- (109.26 KiB) Downloaded 5950 times
- (83.36 KiB) Downloaded 5950 times
Very nice photos Pete, thanks for posting. I will copy and post them into the 2012 Gallery.
Was Lodestone Lake still frozen?
It wont be long until we run the next Whipsaw 2012 #2 :thumbup:
Doc Tari
Thanks Andy, here are a few more.
Here is what the camp fire looked like in the morning. Despite the depth of the hole measuring out at 48", that's not the ground at the bottom, just the ashes. There were a couple more feet of snow below that.
- (77.08 KiB) Downloaded 5899 times
- (75.8 KiB) Downloaded 5899 times
Doc Tari
The areas around the trees were a lot softer than the open spaces.
- (83.24 KiB) Downloaded 5897 times
- (86.7 KiB) Downloaded 5897 times
Doc Tari
Tow straps and shovels were not an uncommon sight...
- (77.14 KiB) Downloaded 5897 times
- (96.95 KiB) Downloaded 5897 times
Doc Tari
Kris playing in the snow
- (129.55 KiB) Downloaded 4711 times
- (141.78 KiB) Downloaded 4711 times
- (117.23 KiB) Downloaded 4711 times
Doc Tari
In places, the Mogs had to squeeze though the trees. The trail was narrower than normal because the high snow put us up in the branches.
- (128.15 KiB) Downloaded 4710 times
- (126.3 KiB) Downloaded 4710 times
- (126.47 KiB) Downloaded 4711 times
Doc Tari
Chris, Kris, and Chris
- (116.55 KiB) Downloaded 4711 times
- (114.51 KiB) Downloaded 4710 times
- (140.79 KiB) Downloaded 4711 times
Doc Tari
Big and Stinky, their names are interchangeable
- (116.95 KiB) Downloaded 4710 times
Doc Tari
With a bit of help from time-to-time, Chris and his Disco did really well, even without tire chains
- (114.75 KiB) Downloaded 4710 times
- (106 KiB) Downloaded 4711 times
Doc Tari
Without a doubt, the snow was the best I've driven on
- (94.05 KiB) Downloaded 4701 times
- (84.65 KiB) Downloaded 4701 times
Doc Tari
Huge tires, ultra low gears, and lockers on both ends made short work of the snow for Alec
- (131.52 KiB) Downloaded 4701 times
- (113.17 KiB) Downloaded 4701 times
- (100.7 KiB) Downloaded 4701 times
Doc Tari
The cab of this Mog fire truck was so big, there was an usher to show you to your seat...
- (116.09 KiB) Downloaded 4701 times
Doc Tari
Chris getting tipsy
- (116.58 KiB) Downloaded 4701 times
Doc Tari
Loadstone at last. The lake was still well frozen and covered in a lot of snow.
- (71.97 KiB) Downloaded 4701 times
- (86.07 KiB) Downloaded 4701 times
- (102.14 KiB) Downloaded 4701 times
Doc Tari
On the way out, low tire pressure, off camber trail, a sharp right turn, and soft snow managed to de-bead the Mog's tire. We re-seated it using camp stove fuel and a lighter.
- (82.2 KiB) Downloaded 4608 times
- (134.92 KiB) Downloaded 4608 times
Doc Tari
A little winching and we were good to go
- (132.57 KiB) Downloaded 4608 times
- (107.41 KiB) Downloaded 4608 times
Doc Tari
Flotation and traction were killer and we had a blast route finding and picking our lines through the trees. This one is going to be hard to top...
- (94.1 KiB) Downloaded 4608 times
- (96.39 KiB) Downloaded 4608 times
