LR3 Rear diff motor
Posted: Sun Jul 07, 2019 3:37 pm
by philchan1974
Hi - replaced my rear diff motor on a 2005 LR3. Fault codes pointed to replacement. However, cannot clear the code and can't clear the "transmission - reduced traction" message on the dash.
the code simply will not clear.
have been told this could possibly be a control module issue (the one behind the battery that's prone to "greening".
any thoughts?
Re: LR3 Rear diff motor
Posted: Tue Jul 09, 2019 11:22 am
Presume you have already tried disconnecting the battery for 5 mins and reconnecting?
Posted: Fri Jul 12, 2019 3:20 pm
by philchan1974
Have done that, yes.
Here's the errors in case someone has a thought.
Rear Diff
P0806-00 (2F) Clutch position sensor - circuit range/performance
( on 12-07-2019 12:59:04 at 202724 km )
P080A-00 (2F) Clutch position is not learnt
