DPS pump
troy
DPS pump
Hello inquiring if anyone knows how to adjust the low speed stop/ anti stall screw for a DPS pump on a 2.5 n/a ? Is this something that can be done on the truck or does it have to be done on a flow bench during assembly? I cant seem to find anything on the net was wondering if someone has experience doing this ? Thanks Troy
radio_05
- Gently Used Condition
Re: DPS pump
I seem to recall you would only set the high idle and low idle when fitted to the engine. Advancing or retarding the diesel by moving the injection pump mounts too.
I'm not familiar with doing than one on the vehicle.
