ROTO FLEX
Posted: Mon Mar 06, 2006 10:14 am
by 96whitedisco
I was on the island Hiway this weekend and noticed a bad vibration from below, the tires are new and balance the steering wheel had no vibration.
Im thinking its my Roto Flex coupler?
Has anyone out there replaced theres?
Has anyone done the upgrade and removed the Roto flex and put a longer drive shaft with the new longer unjoint?
Posted: Mon Mar 06, 2006 5:11 pm
by Greg S
I think you explained the problem when you said you were on --"the Island Highway----".
Nuff said.
Old Island Goat Track
Posted: Mon Mar 06, 2006 8:57 pm
by JD
Greg,
Perhaps the OLD Island Hwy? New one's not too bad .... yet.
JD
Posted: Mon Mar 06, 2006 9:56 pm
I have the Rotoflex on my 99 Disco. I was told over a year ago it was a bit worn, but its quite a ways down the list for replacement. I have, however been watching for a used Disco 1 rear driveshaft without the rotoflex, so far, without success.
Suffice it to say, mine does not create any vibration, although its visibly worn. Might want to look at a few other things. Tied rod ends, for example... Often you won't feel it in the steering even if its the front axle, due to the cushioning that the power steering provides.
Posted: Tue Mar 07, 2006 8:33 am
by 96whitedisco
Is the Roto Flex a dealer item of can i get one from lordco or Auto parts plus.
Posted: Tue Mar 07, 2006 9:05 am
by PaulC
Check with some / all of our supporters. 8)
Posted: Tue Mar 07, 2006 11:52 am
by 96whitedisco
Found a brand new one at MCL for $189.00 and an almost new one at Coast Import Auto for $120.00.
Will replace this weekend.
Posted: Tue Mar 07, 2006 7:32 pm
by 96whitedisco
looked at the Roto Flex today and it had a crack in it about a 1/4 of an inch.
Went straight to MCL got the new one, took me about 1 hour to install, didnt evan need to jack the Disco up.
The repairs on the Disco are so easy, got to love Land Rover.
