Various Defender Parts at Founders Day
withabix
Cylinder bore
#1 Post by withabix » Thu Sep 01, 2022 9:37 am
I have a box of surplus spare parts (mostly small stuff) that I will be bringing to Founders Day (if I finish getting them sorted out!).
Mostly new in bags - some genuine LR, some aftermarket. Prices will be less than lowest of UK/USA/CAN prices (and a lot less for used), open to offers and with no shipping costs!
I may bring my old doors too, or at least photos in case anyone is interested in them.
I've got a set of 5 black aftermarket steel wheels (1290kg capacity) with the old classic Land Rover Michelin tyres on them - will probably advertise these on here soon...buried at the back of my garage at the moment, so won't be able to bring these along to the show.
List probably as follows:
Front RHS door window, 4mm glass. Genuine LR, used VGC.
Pair wing mirrors and arms, used, good, with bolts.
2 Tornado alloy wheels, as new
Bonnet decal Union Jack - new, large
Front door bottom repair section - new
Alloy Wheel nuts with/without caps - probably about 30 available
Lock nut set of 5 with key and code number
Speaker panels (rear, have been trimmed a bit)
Wiper motor cover for vinyl rear door card
Best 4x4 By Far sticker (new)
Gear and Transfer case knobs - used
Indicator/horn stalk - new
Foam bulkhead vent seals - new (3 of these)
Front door window Waist seals - new
Pair headlight surrounds - used
Wiper blade 13” - new
Gas twin bonnet strut kit - new in box, cost $140+Taxes shipped.
Pair aftermarket clear lens headlights with Philips halogen bulbs - used, VGC
Gear stick gaiter (up to 2007, leatherette type) - new
Indicator bulbs - new
Single headlight surround, unused
4 indicator assemblies, used good condition
2 side light assemblies, used good condition
1 brake light assembly, used good condition
Headlight switch, new
STC966 repeater harness. Genuine Land Rover. New old stock in sealed bag These are over $150 retail. May save for eBay!
Bonnet release cable - new
Pair of windscreen brackets - used
Pump for windscreen washer - new
Windscreen bottom foam seal LR055345
3rd brake light Disco or Defender with later door - genuine Land Rover, used.
Window winder bezels - several types
Front washer jet - new, 1 available
Rear washer jet - new, 2 available
Exhaust rubbers various
2nd door window channel short 4 (MUC1714 I think...)
Indicator harness (2 I think, new)
2 pin bulb holder new 4 available
Bonnet hinge bushes 2 pairs
3 pin stop bulb holder 1, new
Bonnet bumpers 1 pair, new
Transfer case sump plug, 2, new
Delphi HFP502 lift pump new - 300tdi disco or defender
Handbrake gaiter - rubber, used good.
Series or defender vent rubber seals used pair - used, good
EGR removal top hose - unused
Pair Defender speakers tested ok, original LR.
Defender wing top vent cover sealed
Nrc4318 suspension spring retainer new, 1 available
Harness lead 3 wire for rear lights, 2 available, new
Led sidelight bulbs pair, aftermarket, new sealed
110 Fuel tank installation bolts ntc2681 pair with square nuts
AMR4956 immobilizer bypass, new, genuine LR.
2 pin bulb holder white, 1 available, new
GlennB
Junior Craftsman
Re: Various Defender Parts at Founders Day
#2 Post by GlennB » Fri Sep 02, 2022 5:59 pm
Possibly interested in the steel wheels what width are they and what’s the offset?
withabix
Cylinder bore
#3 Post by withabix » Fri Sep 02, 2022 8:27 pm
GlennB wrote: Fri Sep 02, 2022 5:59 pm Possibly interested in the steel wheels what width are they and what’s the offset?
Not available yet - details to follow...
Whistlingduc
Apprentice
#4 Post by Whistlingduc » Sat Sep 03, 2022 8:05 pm
Do you still have the gear stick gaiter by any chance?
withabix
Cylinder bore
#5 Post by withabix » Sun Sep 11, 2022 4:42 pm
Whistlingduc wrote: Sat Sep 03, 2022 8:05 pm Do you still have the gear stick gaiter by any chance?
Yes, still got that…
Whistlingduc
Apprentice
#6 Post by Whistlingduc » Tue Sep 13, 2022 2:19 pm
Hi. Where can I pick it up from u?
And how much are you looking for?
