Rear drivshaft
Posted: Thu Apr 06, 2023 9:34 am
by troy
Looking for a rear driveshaft for a 4cyl 109 with a Salisbury in the back . Thanks Troy
Re: Rear drivshaft
Posted: Thu Apr 06, 2023 8:32 pm
by oldgravy
I believe that the part number is the same as a standard rover diff prop?
Re: Rear drivshaft
Posted: Thu Apr 06, 2023 8:49 pm
by troy
No I believe they are different the Salisbury has a longer pinion I believe .
Re: Rear drivshaft
Posted: Fri Apr 07, 2023 9:09 am
by TimberPig
troy wrote: Thu Apr 06, 2023 8:49 pm No I believe they are different the Salisbury has a longer pinion I believe .
This is correct. They’re different part numbers, with the Salisbury equipped shaft being 1.25” shorter from online info. Could just have a driveline shop shorten one as well if you can’t find one.
