200TDi cracks
Posted: Fri Nov 22, 2024 4:01 pm
by oldgravy
Hello, Internet hive mind.
I have a 200tdi head currently sitting at the Lordco machine shop. It's passed a pressure and vacuum check. However there are some small cracks that appear around one of the cylinder's injector / glow plug ports:
(44.37 KiB) Downloaded 46 times
Question: Do you think I can get away with this or is it just likely to spread and cause trouble in a year or two?
Re: 200TDi cracks
Posted: Fri Nov 22, 2024 4:10 pm
by landcrabmechanic
Would be highly advisable to replace the head. No point installing a broken cylinder head.
Re: 200TDi cracks
Posted: Fri Nov 22, 2024 5:20 pm
That is fine. Cracks between the valves are an issue.
Re: 200TDi cracks
Posted: Fri Nov 22, 2024 6:33 pm
by oldgravy
Thanks for the opinions, fellas. 200tdi heads are no longer available so before embarking on a rebuild I thought it wise to check.
