Stripping paint off series tub
Posted: Wed Jun 04, 2025 5:12 pm
by bsa_m21
Hi gang
I’m having a terrible time trying to strip the 3 layers of paint off an old 88”tub. In places it’s so thick, it’s like it was put on with a spatula. I’ve got a gallon of “aircraft” paint stripper, but it hardly lifts any of the paint.
I was wondering about Vapor Blasting or other options. Any and all recommendations appreciated.
Re: Stripping paint off series tub
Posted: Wed Jun 04, 2025 5:42 pm
by steveep
I found that these worked quite well for larger areas (on an angle grinder):
https://www.amazon.ca/Stripping-Grinder ... 0C85FRD9R/
..and these worked well for smaller/tighter areas (on an angled die grinder):
https://www.amazon.ca/3M-Abrasive-405-0 ... 002P55TX6/
Both are 3M products - knockoffs seemed fine for the top product, but the one knockoff I tried of the bottom product didn't work as well
Posted: Wed Jun 04, 2025 7:05 pm
by Gordwedman
bsa_m21 wrote:Hi gang
For something soft like aluminum O think walnut she'll blasting is recommended. What is the major ingredient of your stripper? Methylene chloride is the typical stripper but I don't think this will touch polyurethane paint. Don't know offhand what might Loosen that if that is what someone used.
Sent from my SM-G996W using Tapatalk
Posted: Thu Jun 05, 2025 12:59 pm
by philchan1974
i used one of these with the stripping drum. Works well.
https://www.princessauto.com/en/variabl ... 0009073925
Posted: Fri Jun 06, 2025 9:09 am
by bsa_m21
philchan1974 wrote: Thu Jun 05, 2025 12:59 pm i used one of these with the stripping drum. Works well.
Hi Phil,
I wondered about that, but was leery of having to buy the expensive sander for a one use task. If you have one, any chance I could borrow/rent it from you?
M.
Posted: Sat Jun 07, 2025 7:18 am
by RobinS
I had at least 3 layers of paint on every part of my series one and I was told that having the parts blasted would damage the Birmabright. I checked several brands of aircraft paint stripper and they all claim to remove polyurethane if that is in fact what you are dealing with. It was a lot of work but after getting all the paint of mine , I could still see the slight yellow colour of the birmabright. Just FYI
