I'd like some....
Posted: Wed Dec 06, 2006 9:10 pm
by Glenn D.
I'll be looking for sliders/sills for my 90 in the summer, (after she is running again).
Can you weld on some on some bulkhead outriggers for me sometime? my welding sucks.
I have them.
[email protected]
AGM
Posted: Thu Dec 07, 2006 7:35 pm
by rick.m
For a booth at our AGM , please contact DON MACDONALD our Vice President, as he is looking after the AGM. Date is jan 20th 2007, location is THE CLOVERDALE FAIRGROUNDS. The usual start time is 4pm. Don can be located on our member list posted here. all the best rick.m
Posted: Thu Dec 07, 2006 7:42 pm
by Green Giant
I'm interested in a pair of maxi drive lockers(range rover) Swing away rear tire carrier(range rover) Lift to make room for 34" tires fit under a rangie. Should I make room under my tree??? :D
hmmmmm
Posted: Thu Dec 07, 2006 9:20 pm
by nakedbarra
Hay Carl it sounds like you need to decorate the tree out the front and park on the lawn.
Posted: Thu Dec 07, 2006 11:52 pm
by 96whitedisco
HEY GUYS THE BUMPER WORK YOU SEE ON MORGANS PAGE IS MY CUSTOM MADE BUMPER MATEING THE STOCK LANDROVER BRUSH GUARD. HE BUILT THIS FROM SCRATCH AS I HAD REMOVED MY BUMPER AND LEFT IT AT OUR HOUSE IN POWELL RIVER. MORGAN FIGURED OUT THE BEST WAY TO ADD THE STOCK BRUSH GUARD AND LOOKED AT THE BEST ANGLE FOR THE SKID PLATE.
CHEERS
ANDREW
Posted: Fri Dec 08, 2006 10:02 am
by PaavScan
Costco has a Champion 9500 lb winch for $449.99 including high speed class III mount hitch adapter. That is pluged into the trailer receiver. total weght 112lbs also snatch block & quick disconect power lead.
http://www.costco.ca/en-CA/Browse/Produ ... v=&browse=
Stuart S
Posted: Fri Dec 08, 2006 8:01 pm
by exmod110
Posted: Sat Dec 09, 2006 8:48 pm
by JD
Bolt on sliders for MOD 110's. They do not have the second lateral frame member underneath the body that five door 110's do. That means there is no off the shelf sliders for MOD 3 door 110's; sliders from ARB and others depend on the rear lateral frame member to support the slider.. There are quite a few 110 3 doors around. I'ld like a set.
JD
Vic BC
MOD 110
Posted: Sat Dec 09, 2006 9:28 pm
by HeadDamage
Yep... exmod 90/110 stuff would be good but keep it cheap as we know that exmod 90/110 owners are cheap bastards ;)
Posted: Sat Dec 09, 2006 11:02 pm
by JD
Thankyou... thankyouverymuch.
JD
Posted: Sat Dec 09, 2006 11:16 pm
by HeadDamage
Well I should know... I am one :lol:
hmmmmm
Posted: Thu Dec 21, 2006 9:10 pm
by nakedbarra
Hay Morgan were you able to get a booth at founders day ?
See you at founders day if I can make it.
