LT 230 speedometer fitting
Posted: Tue Feb 06, 2007 3:14 am
by JD
Anyone know how to remove the speedometer fitting from an LT230? Can't seem to find this in the workshop manauls.
JD
Posted: Tue Feb 06, 2007 8:48 am
by HeadDamage
Should just be a allen head or similar bolt holding it in place. I replaced mine with the halleffect sensor from a Disco so that I could run a VDO electronic speedo last spring.
Posted: Tue Feb 06, 2007 10:25 pm
by JD
Andrew,
Do you mean that the alan key is inset and is like a set screw? I'll go look at this again.
JD
Posted: Wed Feb 07, 2007 8:30 am
by HeadDamage
Now I think of it there might be a nut on a stud. Any way on the top side of where it fits into the LT230 there should be a nut or bolt/screw of some sort that is holding a retaining horseshoe like thing. Take that off and the cable and then the inner gear should just pull out unless I'm forgetting something. I'm suprised no one else has spoken up.
Posted: Wed Feb 07, 2007 8:35 am
by HeadDamage
Here you can see it on this link... page seven. It is a stud and nut with the horseshoe thing. Once this is removed the cable then the drive should just pull out:
http://www.landrover.ee/est/files/manua ... _lt230.pdf
Posted: Wed Feb 07, 2007 7:21 pm
by JD
Does look like it should just pull out. Wonder what retains it under bouncey conditions. Thanks for your help. I'll try to lever it out tomorrow.
JD
Posted: Wed Feb 07, 2007 9:25 pm
There is a fork shaped piece of steel that holds the cable housing onto the t. case. The nut and stud bolts the fork down.
Posted: Thu Feb 08, 2007 6:05 pm
by JD
Red90,
It is the housing, or 'sending' unit that the cable connects to that I need to remove. It is inset into the LT230 case.
Rgds
JD
Posted: Fri Feb 09, 2007 11:05 am
What are you trying to achieve??
You remove the fork and then the cable can be pulled away. You can then reach in and pull out the speedometer drive assembly from within the transfer case. See the first page of the document that Andrew linked to. There is an exploded view on page 37-7.
Posted: Sat Feb 10, 2007 12:19 pm
by JD
Red90
Object of exercise is to move the speedometer drive assembly from one LT230 to another without drive assy. This looks like it is pressed into possition (pg 37-16 Anderew's link) and on my donor does not want to budge. May be time to order a new one.
Appreciate your comments.
Rgds
JD
Posted: Sun Feb 11, 2007 9:16 am
It is described right on page 1. It should come out with a bit of prying. People replace them insitu all the time.
