RRC Oil Pressure light?
Posted: Fri Aug 17, 2007 12:58 pm
by Robert Mac
Just wondering if anyone can shed some light on why my low oil pressure light comes on when the oli is at its correct level and has just had an oil change. The light was flashing on and off prior to the oil change and would go out briefly when the engine idled high. Now it just stays on.
mmmmmmmmmmmmmmmmmm?
any answer or theories?
Cheers and thank you
Rob Mac
Posted: Fri Aug 17, 2007 1:35 pm
by Robert Mac
That sounds great how do I test my oil pressure switch and I will give it a try?
Thank you
Rob Mac
oil light
Posted: Thu Aug 23, 2007 8:52 am
by Robert Mac
Oddly enough my oil light has gone out and now my charge light and check engine light is on and the rover runs like a bag of dirt misses at higher rpm.
will be putting a test meter on the battery both running and static.... :shock:
Thanks again
