trailer lights very dim!
Posted: Mon Mar 31, 2008 5:22 pm
by Robert Mac
Hey wise landygicians,
wondering if there is any magic you cand send my way. I just towed my boat and trailer home today and have the lander rover pig tail hooked up to my range rover but for some odd reason the lights are barely noticeable...... turn signals brakes and marker lights.... you know the important ones. Is the pigtali faulty or ?
looking for ward to your wisdom.
Cheers for now
Rob Mac :D
hmmmmm
Posted: Mon Mar 31, 2008 6:40 pm
by nakedbarra
Maybe a bad ground? or dirty / corroded contacts?
Dim lights..
Posted: Wed Apr 16, 2008 7:44 pm
Dim lights normally point to low voltage or incorrect bulbs?
Is it the first time you have used the hitch connection?
cheers,
Posted: Wed Apr 16, 2008 11:03 pm
by Doc Tari
Rob,
If all the lights are dim, it's likely something that they all have in common, my bet is the ground, as Andrew points out. This is not uncommon on boat trailers given the water. Make sure there's a ground wire through the pigtail and it's not grounding through the hitch only. Also check that the ground points on the truck's pigtail and for each trailer light are clean. Hope this helps.
Pete
Posted: Mon Apr 21, 2008 11:54 pm
by Robert Mac
:D Thank you, I will check this out now that the weather has cleared and the rains and snow has subsided....
Rob Mac :D
thank you!
Posted: Sat Jun 14, 2008 2:18 pm
by Robert Mac
All fixed now :D
All Fixed now ....
Posted: Sat Jun 14, 2008 3:42 pm
Good to hear its all fixed now.
So don't keep us on the edge of our seats.... what was it?
What was the fix?
thank you!
Posted: Sat Jun 14, 2008 6:25 pm
by Robert Mac
It turned out to be a combination of corroded contacts and an internal broken wire just barely making contact...... Who would have thought!
:D
