Fuses
dchsw
I had the same problem with my '86 90 last year. I was unable to find any the correct size so used lordco ones. The just about fit if you push hard and despite not quite being in as far as they need to go the one I replaced last year has not popped out so far.
Later defenders ('89 onwards) have modern colour-coded spade fuses so getting correctly sized replacements may be a case of buying genuine parts mail order.
Good luck, and do let us know if you find any.
Cheers, David
Cheers, David
