200 tdi Air Filter
N Hamelin
200 tdi Air Filter
For those of you running the 200tdi and defender air filter canister, where are you getting your replacement air filters? I have a Crosland 958 filter in mine, but was wondering if there is a readily available alternate from the local parts stores?
Hi Neil,
I was told when I did mine that many of the Defender and Discovery air filters are the same, and that Fram CAK253 was the one to get. Might want to give one of those a try.
Out of the box it has a plastic air cavitator that needs to be trimmed off, but test it for size first before you cut off the plastic in case you need to return it. I got mine in stock at Lordco here in Armstrong. They said it's fairly popular in diesel forklifts.
cheers, Dave
cheers, Dave
The air comes in radially from the side. If there is water in it or large particles, it will eat a hole through the filter. The plastic and vanes deflect and then spin the air to the outside of the can. This allows the water to drain and the large particles to fall down to the bottom. As a minimum, some form of deflector needs to be there, but the stock design is the best as far as air box design goes. The arrangement of the stock 200TDI Defender airbox has been done in a very specific and well thought out manner.
If it was just a plain cylindrical filter, the air should be ducting to impact the back end of the filter. You don't want the high velocity inlet air hitting right into a filter element.
N Hamelin
Are you sure it was the correct part number for the Defender 200TDI? NTC6660? The Disco 200TDI filter is different and not finned.
Sizing and other ones shown here: http://shop.dingocroft.co.uk/acatalog/Air_Filters.html
This looks like the FRAM one I purchased at Lordco:
http://shop.dingocroft.co.uk/acatalog/NTC6660D.jpg
It's the generic replacement for the NTC6660.
Maybe CAK253, http://www.power-21.com/FramPower21i/Pa ... &pn=CAK253
A billion cross references there.
Really common is Baldwin PA1667-FN
Edit, Dave beat me to it. Looks correct....I guess I should read first.....LOL
N Hamelin
Another big cross reference page, http://shop.efhereford.co.uk/defender-2 ... -757-p.asp
rayhyland
- Drip Dry
I have a k&N that I got through Rovers North but it doesnt have the plastic vanes. Luckily I didnt throw the old original away, so I will try to cut the vanes off and apply them to the K&N. I did notice that the filter would clog-up where the inlet is, very quickly, so I have been rotating the filter.
If you are using a K&N, I would suggest reading this thread.
http://www.aulro.com/afvb/technical-cha ... nally.html
PaulC
