Disco 1 lifts
Posted: Sat Jan 15, 2011 6:16 pm
by jeepingpw
Looking at lifts for a Disco 1
Has anyone done a body lift?
Suspension lift is better, really cheap on E-Bay UK,
but I have read that a 2" needs 3 deg. of caster & 3" needs 6 deg. of caster.
I've done alot of Ford lifts & looking at the Rover, why not lower the stock Radius arm brackets?
Has anyone tried this?
Posted: Sat Jan 15, 2011 6:43 pm
by PaulC
I have /had OME 2" lift for 4 years (driven on road and on trails extensively), no problems no adverse steering or drive line issues at all. (98 Discovery)
I'm just switching over to a 3" OME lift with relocated rear shock mounts, I don't expect any adverse issues. But likely to have some minor drive line vibrations?
Posted: Sun Jan 16, 2011 10:10 am
by jeepingpw
PaulC,
Are you still useing the Roto Flex at the rear axle?
Posted: Sun Jan 16, 2011 5:02 pm
by PaulC
1998 Discovery's have U-joint drive shafts...so no :)
Posted: Sun Jan 16, 2011 9:21 pm
by discojonny
I have the 2" OME lift and just put in the offset bushings. they made a huge difference, and I am in the process of destroying my second roto coupling in 15000kms.
