how to test center differential lock
Posted: Sat Sep 17, 2011 6:01 pm
I was recently off roading a bit and got stuck in a wash out. The right rear tire was in the air while all others were firmly on the ground. I was in low with the ceter differential lock in but the back wheel spun. I was under the impression that if all is well the front wheels should have pulled me out. The differential lock light was on but it has always flickered when the lock is engaged. Is this normal or should it burn steadily?
How do I test to see if the differential lock is functioning? Is there a likely source of trouble if it fails to work or is this a job for the transmission shop?
jeremy
jeremy
