Coil wiring conections
Posted: Sun May 27, 2012 2:36 pm
by knightracer_08
So I'm trying to wire in my new coil however I'm not sure what terminal needs to be connected to where, the old Lucas one had cb and sw terminals, one wire went to the distributor and one to the fuse block, the new coil has pos and neg terminals, what needs to be hooked to what? Thanks
Re: Coil wiring conections
Posted: Mon May 28, 2012 11:35 am
by John
Pos term to fuse block (switched power), neg to distributor.
Posted: Mon May 28, 2012 12:53 pm
by knightracer_08
Thanks got her running, coil gets very hot when hooked up though, not the exact coil but a generic one.
Could it be caused by bad wiring else where or is the series 2 externally resisted?
Posted: Tue May 29, 2012 10:03 am
by RoyP
Coils get quite warm/hot normally (heat dissipates through the case) so likely not a problem.
