Diesel injector service
Posted: Thu Oct 04, 2012 12:54 pm
by ishapiro
Hi All,
Can some one recommend a good diesel injector service shop in the mainland area? I need my 300tdi injectors serviced/calibrated.
Thanks.
Re: Diesel injector service
Posted: Thu Oct 04, 2012 8:26 pm
by BOlson
New West fuel injection
Talk to Gord , he's very knowlegable with
all aspects of Diesel injection
N W Fuel Injection Service (1983) Ltd
www.nwfuel.ca
Posted: Fri Oct 05, 2012 11:16 am
by ishapiro
Hey thanks for that tip!!
Just talked to Gord he sounds very knowledgeable.
Hope they will be able to fix the issues.
Posted: Tue Oct 16, 2012 6:55 pm
by bf900
Hey, did you end up taking your truck in to new west? Did they resolve the issue? Good shop?
Posted: Wed Oct 17, 2012 2:20 am
by ishapiro
Yes, I did go there last Thursday. I worked with Gord and Morgan and they were very helpfull and friendly. My 300tdi EDC had a slight smoking problem when cold. It would smoke and misfire only at around 1500 RPM so I assumed it would be fuel injection related as everything else looks good. They cleaned and calibrated the injectors but that didn't solve the issue. Then Gord mentioned the valve clearance. I did the valves 15K when I first got the truck so would never suspect that. I got back home and on the weekend rechecked the clearance. It seems to have solved my problem (knock on wood) :-).
In any case I would highly recommend them as they are very professional and look well equipied to deal with LR unique stuff.
Posted: Sat Oct 20, 2012 4:30 pm
by bf900
Great thank you for the update.
