200Tdi Air filter housing drain
Posted: Thu Oct 18, 2012 4:01 pm
by DBrands
My 90 is missing the soft rubber drain ("dust ejector"?) on the bottom of the air filter canister.
I went to a tractor parts store, but they wouldn't help me unless I had a part no. I wandered around the yard looking at tractors to try find a suitable version, but wasn't very successful.
Is there a better alternative?
If you can't picture what I am referring to... here is a similar one for a massey ferguson.
http://www.laboutiquedutracteur.com/130 ... -drain.jpg
Re: 200Tdi Air filter housing drain
Posted: Fri Oct 19, 2012 7:05 am
NRC8955 if you want a new one or get one from a wreckers in the UK.
http://www.thexmod.com/item_detail.asp?id=828
Posted: Wed Oct 24, 2012 11:34 pm
by DBrands
That's the ticket! Thanks.
Posted: Fri Nov 09, 2012 3:08 pm
by rayhyland
I basically made one out of a 10" section of bicycle inner tube that I hose clamped to the outlet. When the engine is running the vacuum clamps the tube closed so air comes in the proper side inlet. When the truck is not running there is no vacuum so water can drain out the tube.
