Was at the Reveal Event for the new Range.....
Posted: Thu Nov 22, 2012 7:36 pm
by Russ
Re: Was at the Reveal Event for the new Range.....
Posted: Fri Nov 23, 2012 10:18 am
by swamijake
Angle of attack and angle of departure look woefully inadequate. I'll stop by and have a look in person, but so far it looks like a glorified station wagon.
Posted: Fri Nov 23, 2012 12:39 pm
by Russ
It's sitting at access height. Suspension raises. See here for Departure and Approach angles:
http://www.landrover.com/ca/en/lr/all-n ... ercharged/
You'll need to click on "Dimensions and Capability" which is on the left side of the web page.
Posted: Sat Nov 24, 2012 6:22 am
by exmod90
black friday MSRP ?
gerry - prince george
Posted: Sat Nov 24, 2012 3:33 pm
by e.prevost94
It looks very cool. Very well equipped, and tastefully trimmed. But I have a feeling it it would be less than useless off road. Looks like way to concepty to be any good in the bush.
Posted: Sat Nov 24, 2012 9:08 pm
by Russ
exmod90 wrote:black friday MSRP ?
Anywhere from $120k to $150k on avg.
e.prevost94 wrote:It looks very cool. Very well equipped, and tastefully trimmed. But I have a feeling it it would be less than useless off road. Looks like way to concepty to be any good in the bush.
Well, have a look at the suspension statistics for travel, the numbers on how rigid the Alluminum frame is, the low end torque of the supercharged, the lock in the t-case (and that it still has a t-case), the traction system, the exceptionally low centre of gravity, and the locker in the rear diff.... To name a few. Also you should check out the cool air induction system to keep water out.
Remember, even as a new vehicle that sell to mostly people that don't use it in North America it is still used as intended overseas. They all have to have a minimum approach, departure, and breakover angle, ford at least 500mm of water (most do 700+), and traverse at 37 degrees.
As much as someone would not want to scratch a truck that expensive, with some mud tires it would out-wheel just about anything out there as a stock vehicle.... Maybe even a 110? lol
Posted: Sat Nov 24, 2012 9:12 pm
by e.prevost94
As much as I can respect that, there is no replacement for solid axles. Independent is good for on road, but lacks off. Not to mention that the wheelbase is way to long, and the tires are low profile which don't help off road.
Posted: Sat Nov 24, 2012 9:18 pm
by Russ
I don't argue the solid axles, but technology and ride modules allow independent suspension to reach and compress as you would hope (have a look at the video from the wheels event you guys put on and watch the LR4).
Tires can be changed.
Size you are right about though. I'm a Jeep driver so I know the value (and detriment) of a smaller wheelbase. Personally I'm an LR4 fan, but even that is pretty big. That said, you 110 drivers are pretty long just like the 4 door Jeep JK's that are out.
Posted: Sat Nov 24, 2012 9:25 pm
by e.prevost94
For as big of a tank as it is, I'm sure it'll surpass my expectations. I personally like the looks of it, but I don't think it'd make it on any of the hardcore trails. Speaking of which, what are you planning on bringing to the toy run tomorrow?
Posted: Sat Nov 24, 2012 10:13 pm
by Russ
I'll have my dogs with me so taking a new Rover wasn't an option. I'll have my TJ on 36's.
Going to wear my Land Rover of Richmond coat so hoping it will be easier to bump into a few of you guys.
Posted: Sat Nov 24, 2012 10:31 pm
I was at the new RR launch also, a very impressive night over all.... really like the new Jag too
It was good to see they noted the begins of the Range Rover in 1970 with the now called "Classic"
