Axle Breathers, Water Ingress, and other issues......
Posted: Wed Apr 24, 2013 5:03 pm
As it turns out, Andy's truck was not the only victim from our Land Rover Play Day at Triangle beach.
I decided to check the oil in my axles last night and found grey mayonnaise :shock:
Serves me right for forgetting that I have not as yet swapped out the stock IIA axle breathers for extended breathers. Further serves me right for stopping mid lake. This got me thinking about other areas and my guess is that the Transmission is likely the next vulnerable component if you do not install wading plugs.
I see an evening spent doing fluid changes next Monday.
In other news the oil feed line to my turbo has has developed two leaks. One at either end being the turbo fitting and the remote oil filter but actually on the crimped fitting wher eit attaches to the hose. This wasn't bad before the play day but is so bad now that manifold smoke off the Turbo is entering the cab on occasion and my parking spot at work has been renamed "Lake Castrol"
I have a couple of questions which hopefully some of you in your experience can answer.
1) Do the extended axle breather's work well? Does anyone have a spare set?
2) What is the best way to clean my axles and transmission out? I figure drain and fill, drive, and then drain and fill again.
3) What is the standard oil inlet fitting for a Garrett T3? I figure I can just get an Areoquip or Russell hose from Mopac.
4) Oh and the Peugeot Diesel puts out an incredible amount of blowby, any opinion on the 300TDI oil seperator and how well they work? I figure I can adapt one easily to work on the Peugeot.
5) Lastly I am thinking of getting my Turbocharger rebuilt...any recommendations for a good company to do this?
Thanks Guys,
Thanks Guys,
