Few questions about my DII
Posted: Wed Aug 28, 2013 6:07 pm
So I've owned my '01 D!! for about 6 months now, and I'm really enjoying the ownership of this rig. Been on many travels and adventures since I purchased it. Since then, suspension upgrading has been on my mind, but before I get into lift kit suggestions, I have one question; is the rear end normal to be soft? (coil and spring, no air suspension). I've noticed that when I go over speed-humps, or general dips along the roads, the rear end tends to bounce alot. I'm curious if that's normal? In my mind, I keep thinking I need new shocks, or a stiffer spring (or both) to have less bounce, but not ruin the articulation/off-road performance.
If the case is only to replace worn out shocks, I'm most likely going to replace them with Bilsteins (not sure which, but keeping ride hide stock).
With regards to lift kits, I'm looking for a 1.5" - 2" lift, but curious about how they work. Does the spring lift the vehicle to the desired height?
Thanks!
Gregory
Thanks!
Gregory
