300tdi lift pump
Posted: Sun Aug 09, 2015 8:16 pm
Hi everyone,
While driving home last week on the highway my 110 started to bog down.
I pulled over for a few minutes to let her gain some idle again & eventually made it home.
After checking the lever on lift pump (in different positions on the cam) it looked like it failed.
I removed the pump to check it & the lever / suction worked just fine...
As anyone experienced the same problem?
Thank you
Thank you
