Kodiak Mk.III Air Control
Posted: Thu Feb 04, 2016 8:42 pm
by The_Anachronist
I have a Mk.III Kodiak in my '63 109SW. It does not have the air control system (no knob, no cable, no damper) which closes off the 4" fresh air duct.
I don't think it ever did, but I am not sure if it was supposed to.
Do you find that air blows in passively? What about dust and crud?
Should I try to build an air control damper?
Re: Kodiak Mk.III Air Control
Posted: Fri Feb 05, 2016 7:30 am
by harv
My 63 88" has a the air shut off but I never ever turn it off. Maybe you'd close it for deep water. Even if it's quite dusty I would typically keep the fan on as the air it gets is probably better than the dust inside.
Posted: Fri Feb 05, 2016 10:01 am
by The_Anachronist
Thanks for that!
If anyone has one of these to sell, I would be interested.
Actually I would be really interested just to see the thing, too, to figure out where it fits... I must say I can't see where the hell I would be able to jam it in on mine but I have been surprised before... :shock:
Posted: Fri Feb 05, 2016 6:11 pm
by Rambler
Pm sent
Posted: Sun Feb 07, 2016 9:35 am
by island dormy
Hello
My 1962 Dormobile has a Kodiak with the 4 inch air intake on the side. It has no air shut off flap. At highway speeds air will sometimes just barely flow into the rover. I built a small scoop to try and get more air in. It really made very little difference, so I do not think you need a flap if the air intake is on the side.
Some of the Kodiak installations ran the air intake under the fender and up to the radiator grill area for a real ram effect if you have this style you may want a air shut off flap.
If you need a new 2 speed heater control, the one with the funny little round 3/4 inch long resistor that gets red hot, they are still available from Lordco. ( I think everybody with a old rover has burnt their fingers on this a least once).
I just JB Welded the old rover heater knob onto the new heater switch by letting the JB weld set up a little then threading the Rover part on.
Victor 1962 Dormobile
Posted: Mon Feb 08, 2016 8:01 am
by harv
Do you know what the 2speed switch is stocked as at Lordco (P/N or name)? I could use one of these.
Posted: Mon Feb 08, 2016 8:02 pm
by island dormy
Hi Harv
Sorry I do not have the part number but this is what you want. They are available in 2-3-4 speeds with screw or spade connections and push or pull on( Land rover) as well as with built in fuses. Price is anywhere from $20-60. If you get a parts person with some knowledge they will know where to find it on the shelf, it is universal on many 1960s vehicles
The 3 speed seems to work nice.
http://www.colehersee.com/home/item/cat/143/68028/
Posted: Mon Feb 08, 2016 8:11 pm
by Rambler
harv wrote:Do you know what the 2speed switch is stocked as at Lordco (P/N or name)? I could use one of these.
Should you have any problem. You can also get the cole-hersee from 3brothersclassicrover.com in Ont. Mine was ~$30 last year.
Posted: Tue Feb 09, 2016 6:26 am
by harv
Thanks guys. I'll give one of those a shot.
