Texaco MTF 94
Posted: Mon May 02, 2016 4:14 pm
by tony
HI, Texaco MTF 94 supersedes the ATF in an LT-77 gear box, what is the equivalent in another brand? Red 90 :D
Re: Texaco MTF 94
Posted: Mon May 02, 2016 4:53 pm
There are a bunch out there. Most people use Redline MTL. Available at any performance shop.
Most OEMs like Honda and GM do equivalent MTFs as well.
Re: Texaco MTF 94
Posted: Mon May 02, 2016 5:50 pm
by tony
Thanks again.
Re: Texaco MTF 94
Posted: Mon May 02, 2016 7:19 pm
Here is my page on the subject comparing properties of different MTFs around the world.
http://www.red90.ca/rovers/MTF.htm
Hard to compare the OEM stuff as they don't like to release specs, but it "appears" the Honda and GM stuff are similar to MTF-94.
Anyway, for the North American person, usually Redline MTL is the easiest choice. It has the same running viscosity as MTF-94 with a lot better low temperature viscosity. If you were living up in the Territories, it might be worth running something lighter.
