Driveline angles
Posted: Sun Nov 26, 2017 11:00 pm
Looking for some guidance on my driveline set up.
I feel like I understand the basics but I'm not clear on how much fudge factor there is.
Here is what I have
Transfer case angle: down 2 - 2.3* measured off the rear surface of the parking brake
Rear pinion up 5*. Measured on the drive shaft flange
Drive shaft slope: 7-7.5* measured quite roughly by olding a piece of tubing in place as I don't have a drive shaft in
Front of TC is, not surprisingly, the reverse of the rear. (measured from the output flange)
Lost my notations on the front angle so will have to check back tomorrow.
So I know with a standard shaft I should be parallel angles and with a DC shaft I should have the pinion pointing towards the TC with zero angle.
My question is, how much tolerance is there. I'm about 2.7 - 3 degrees off parallel angles for a standard shaft and about 2-2.5 degrees away from zero angle for a DC shaft.
The other consideration is that I don't have the weight of the engine on the chassis yet, nor other things that may affect weight like passengers and equipment. I've used ratchet straps to compress the springs a bit to simulate having the engine weight on the chassis but I'm not sure how much all of this will affect the angles
Here is what I have
