I own a 1986 LR90 2.5 diesel n/a [ exmod ] . Cabin heat [ especially on the driver's side ] is an issue during the hot days of summer here in Prince George .
I do recall some former chatter about this on a prior thread last fall ??
I checked out a company located in Lethbridge AB ' http://www.b-quiet.com ' which is more geared to sound insulation . I'm looking for a simple solution to reduce cabin heat from a baking to a warming oven .
thx . any input would be appreciated . Gerry [ Prince George ]
Cabin heat LR90
exmod90
- Half Shaft
Closed cell foam works well. It is a good insulator, acts as a moisture barrier and does not hold water. The cheap source is carpet underlay. There is a link in a thread to the stuff at Home Depot on these forums.
Here: http://roverlanders.bc.ca/roverforum/vi ... php?t=3236
rayhyland
- Drip Dry
exmod90
- Half Shaft
I came across this product ... looks like a solution to radiate heat .
' http://www.thermotec.com '
It is sold at Mopac Auto Supply in Langley [ 19950-84th Ave ] .
Gerry
Gerry
seapotato
red90 wrote:Closed cell foam works well. It is a good insulator, acts as a moisture barrier and does not hold water. The cheap source is carpet underlay. There is a link in a thread to the stuff at Home Depot on these forums.
I'm using that stuff, can't argue with the price.
another good cheap product is the silver bubble wrap stuff you get for insulating hot water heaters. seems to work really well.
I've used it on the tranny hump in a few different cars.
