Ad blocker detected: Our website is made possible by displaying online advertisements to our visitors. Disable your ad blocker to continue using our website.
AuZZZie
#1
Post
by AuZZZie » Mon Nov 21, 2011 6:06 pm
Anyone have tips/guide/expiernce on replacing the transfer case mounts on a D1 Automatic? One of mine is shot so I've got some new ones on order.
Hoping I can basically just slap a jack under there. Slide the old ones out, slide the new ones in.
#2
Post
by DaveB » Tue Nov 22, 2011 7:08 am
That's the usual method. I replaced mine for my D2 recently. It was a tight job, but doable as long as you unbolt the nuts on both sides. I'm pretty sure the D1 will be similar.
have fun. Dave
AuZZZie
#3
Post
by AuZZZie » Tue Nov 29, 2011 2:17 pm
Dave.
I'm assuming the DII mounts are the same, but did two of your bolts on the passenger side mount go into the oil cavity?
I can't believe they would make mounts that force you to drain the TC. Ridicilious design.
