How to drain water from the door latch well?
markmascotto
#1 Post by markmascotto » Sat Oct 03, 2015 8:40 pm
I've recently replaced the rear door on my 110 Hard Top and notice that there is no way for water to drain out of the deep latch well. Does anyone have a solution to get rid of rainwater and avoid rust?
Re: How to drain water from the door latch well?
#2 Post by red90 » Sat Oct 03, 2015 9:00 pm
What do you mean by "deep latch well"?
markmascotto
#3 Post by markmascotto » Sat Oct 03, 2015 9:02 pm
The recessed "well" around the door latch.
#4 Post by red90 » Sun Oct 04, 2015 7:31 am
Maybe you could provide a picture. I don't quite see what is the problem on mine. The door skin aligns with the bottom of the frame of the latch well. Yours might be a different version though.
The biggest problem I see with all these doors is the aluminum and steel touch and then they both corrode away. If you want a long lasting door, you can get ones that are all galvanized steel. http://www.sp-4x4.com/DEFENDER_GALVANIS ... -steel.htm
markmascotto
#5 Post by markmascotto » Sun Oct 04, 2015 10:32 am
Here is a picture of the door and recessed latch. You can see the start of the rust at the bottom of the well area.
https://www.flickr.com/gp/136763653@N02/49Ko0T
#6 Post by red90 » Sun Oct 04, 2015 4:32 pm
Hard to see but the skin looks mounted a bit high. Rust there is common as it is hard to paint in there.
