Idle Drops at Startup 1998 DISCO 2
98DiscoVncvr
#1 Post by 98DiscoVncvr » Wed Nov 09, 2016 7:15 am
Good Day!
At start up...the idling drops below 750, actually drops to 200-300, and sometimes completely dies out. When I try again and rev up then drive, it seems to be fine. This usually happens after I have using for an hour or two and have been turning the truck off and on a couple times. The truck runs great and will start up and idle just fine in the mornings, starting up from cold. This drop in idle will usually just happen after use. PLEASE HELP
Re: Idle Drops at Startup 1998 DISCO 2
#2 Post by bsa_m21 » Sun Nov 13, 2016 10:17 am
Check for cracks in the small hoses that connect to the intake plenum.
Also, clean your IACV on the side of the plenum.
Check the Rave manual for more details.
If needed, get it here:
http://www.landroverresource.com/
