Does anyone have one of these. It is a small amplifier that is mounted inside the headliner near the alpine window on the RH side.
Ray
DISCO 1 AM RADIO AMPLIFIER?
Forum rules
tallgypsy
- Gently Used Condition
Re: DISCO 1 AM RADIO AMPLIFIER?
Ray,
Do you have the P/N? I was running a Disco 1 head unit and amp in my RR. Late last year when I put the car back on the road I had very low volume coming from the system. I assumed that the amp had failed but I have not validated that - maybe the problem is in the head unit. Both are available to you if you want to give them a go.
tallgypsy
Thank you John
I took the unit off the truck.
Picture posted below.
Part number is AMR5270 "AM/FM amplifier".
Ray,
That's different to what I have - AMR3853
tallgypsy
John can you call me about this I would like to give it a try?. Ray 604 925 1260
