Carbon deposit removal
DiscoSlice
Learner Driver
#1 Post by DiscoSlice » Thu Jan 30, 2020 2:05 pm
Wondering if anyone out there has some success stories with cleaning carbon from piston tops. I’ve always had luck just with a gentle scrub and some WD-40 or something.
I can’t put it back together looking like this and I’m not keen on pulling pistons and rebuilding the bottom end.
I’m not after shiny new looking pistons but they’re pretty bad.
(140.64 KiB) Downloaded 215 times
Sure doesn’t look like I’ve burnt 94 octane for the most part of 100000kms. I wasn’t losing much oil so I don’t think that’s a result of valve seals.
landcrabmechanic
Hot Manifold
Re: Carbon deposit removal
#2 Post by landcrabmechanic » Thu Jan 30, 2020 2:24 pm
I use BNAC Gom 1221.
Call Chris at BNAC Better natural alternative chemistry in coquitlam .
+1 877-566-2622
Tell him Scott sent you.
I use this stuff to decarb VW diesel manifolds and it works wonders.
DiscoSlice
Learner Driver
#3 Post by DiscoSlice » Thu Jan 30, 2020 3:16 pm
Appreciate that Scott 👌
radio_05
Gently Used Condition
#4 Post by radio_05 » Sun Feb 02, 2020 6:29 pm
I've bought off-shelf decarbonizing solvent, and it didn't work very well. It took lots of elbow grease, and either red or green scotchbrite. I expect your pistons are alloy, so I'd be careful on what to scrub them with.
On cast iron cylinder heads faces, I've cleaned them up the same way, and have read the tip of using a piece of aluminum scraper, which won't marr iron or steel.
#5 Post by swamijake » Mon Feb 03, 2020 11:05 am
Chlorinated brake cleaner and a scotch bright for me. Respirator and lots of fresh air a definite requirement.
radio_05
Carbon buildup, no ethanol?
#6 Post by radio_05 » Mon Feb 03, 2020 12:27 pm
Reading your post again, it DOES look like you ran 94 or 97 octane for the last 100K or so. High-test gasoline often contains little or no ethanol. Ethanol fuel, once and awhile, can help to clean out deposits on old engines. I ensure I never use ethanol-containing fuel on small engines though, especially two stroke, and opt for high-test then, which usually omits the ethanol.
Something to think about after you have it cleaned up and back together.
