Discovery II head gaskets
DiscoSlice
- Learner Driver
Re: Discovery II head gaskets
Look forward to hearing about your completion! Just wrapped mine up, was a long battle but sooooooo worth it.
rgallant
Well Saturday went to hell in a handbasket, 11:00 to 7:00 pm Clean gasket material from block, all but 1.5 hours of that time,many many bad words were used. Last hour was cleaning bolt holes, that at least was the expected time frame.
I also cleaned up some wiring loom while I waited for the Gasket cleaner to "work"
Used gasket removal spray
Hard plastic scrapers
Next to zero effect after 2 hours - ok I killed 3 scrapers
Then I did a bit of research and found a resin based scraper for gas stove tops and granite countertops popped down the hardware store and progress began ! it is called a Skraper Skraper
Before - Note carb clean works really well on piston heads
A few images
Block Before
https://i.imgur.com/OdRBAbm.jpg
https://i.imgur.com/4o1GpKs.jpg
Left side after 1.5 hours
https://i.imgur.com/hngY0SU.jpg
At 7:00 pm finished
https://i.imgur.com/DFjMsv9.jpg
https://i.imgur.com/ieN7iED.jpg
A few images
Block Before
At 7:00 pm finished
rgallant
Wiring loom fix was pretty easy
Low tack cloth wiring tape
Braided loom
MAF Sensor wire Before
https://i.imgur.com/QcoVkdA.jpg
Taped
https://i.imgur.com/1m1v2j8.jpg
Loom in place just needed zip ties on each end
https://i.imgur.com/TSKhFSP.jpg
Braided loom
Taped
Good work Richard, its all down hill from here .................
rgallant
GRRRR 3 days and all I got done was get the heads on, right side is torqued down and good the left side is started, I can not finish that side. I need a torque wrench with a small head, extensions and wobbles do not work. One stupid bolt on the bottom of the head.
I did get some more bits degreased and de-varnished so things are proceeding.
I found a torque wrench that should work,with luck :)
Are you doing that with the block in the car? Ouch!
rgallant
@swamjake yup found all kinds of muscles I have not used in years and they are all complaining :)
rgallant
Success, kinda of found a "wobble" extension that worked. The problem is the bolt appears to have 70 Lbs of torque on it, it should not. After a ton of reading I am going to loosen it off and re-torque, it is the last one in the chain.
The extensions : note angle is exaggerated for th photo
https://i.imgur.com/mCOj31J.jpg
Everything in place :
https://i.imgur.com/C0EYABr.jpg
Looking down to bolt location
https://i.imgur.com/XwFcMYy.jpg
rgallant
Done and finished my shoulder hurts but I have it sorted out.
After reading a lot on several hot rod forums I went with removing that nut & washer re-lubing and reseating. It just made me feel better.
It took 45 minutes start to finish and the booster heat guard bracket had to be removed, but I got it torqued correctly.
A quick double check on both heads torque in the am and I can get back in the assembly groove
rgallant
rgallant
The valley pan gasket is a pain to get set just right, it takes a lot of fiddling to seat correctly - in my case the left side was great the right side took some work,the right rear was great the right front was low a bit. If you do this read a lot and dry fit a few times.
I suspect a lot of the issues around leaks in this area are related to fitting issues.
https://i.imgur.com/ipbhIZx.jpg
Bolt cleaning took a lot of the day, turns out the old intake bolts had plumbers paste on them, that is just weird as the bolt do not enter the cooling jacket.
After 5 days of soaking in gasoline that stuff was still hard as rock. As luck would have it the only thread chasing kit to rent was out.
In the end I used my old warped head as a chase and used this process:
After on top, before below
https://i.imgur.com/smjas63.jpg
State of the bolts overall
https://i.imgur.com/Dr1NgAP.jpg
Final job was replacing the throttle body heater, mine leaked and has been bypassed but as long as everything was apart, I figure replace it.
It is very easy:
https://i.imgur.com/NX6KLVR.jpg
https://i.imgur.com/GTKK2U6.jpg
Final job on the day was to install the SAI tubes into the Block, just some copper anti seize and 18 mm open end wrench. nice an easy with exhaust off
- hit the bolt with gasket remover spray
Screw the bolt into the head
Let sit for 15 minutes
Pull it and rinse (hot water)
Scrub with a bristle brush
Clean grooves with an exacto knife and jewelers screwdriver - this stuff is hard
Run into a second block hole with degreaser
rinise again
Run into the block in a 3rd hold dry
Repeat if required
It is very easy:
- pull the old one
Clean the mating surface,used 2000 grit sandpaper and steel bar
Copper gasket spray on both sides of the gasket
Set the gasket in place
Put the manifold in place
Bolt it down
DiscoSlice
- Learner Driver
Almost there! I bypassed my throttle body heater... I warped three new ones before I just simply had enough.
Have had enough run time on mine to speak very highly of the NGK double platinum plugs I installed. Major improvement over the Bosch platinums that were in there.
rgallant
@discoslice mine will likely stay bypassed too, I am going to route the cooling line directly back to the expansion tank. Then just block the heater ports. It will be a lot cleaner setup.
There is a solution for you. Only one province to the right.DiscoSlice wrote: Tue Feb 25, 2020 10:53 am I bypassed my throttle body heater... I warped three new ones before I just simply had enough.
https://www.sportscarcentre.ca/MGM000010K?mid=948
Good to get this as well. https://www.sportscarcentre.ca/aluminiu ... -s?mid=948
DiscoSlice
- Learner Driver
Whoa! Of all the mods and parts I’ve seen in my time I’ve never come across an upgraded throttle body heater. Those are rad. If I thought I needed that heater for any purpose at all I’d be all over that. Nice looking bleeder upgrade too. I’ve been meaning to get the one from carrs4x4 for a while now.red90 wrote: Tue Feb 25, 2020 11:56 amThere is a solution for you. Only one province to the right.DiscoSlice wrote: Tue Feb 25, 2020 10:53 am I bypassed my throttle body heater... I warped three new ones before I just simply had enough.
You need one. Your throttle will ice up without one.
rgallant
Well as of today I will lots of time to get her sorted out just got laid off, sucks but the wife says I can mostly retire
Tony4921
I have been running a 4.0L D2 with no TBH for the last 5 years, no problem at all.
rgallant
It is pretty rare to getting icing down here,up around Dawson Creek I would be way more concerned. I have a few ideas around a controllable bypass, I will post up if any comes of it
Or you could spent $75 and fix it properly forever.
DiscoSlice
- Learner Driver
Sorry to hear about the lay-off. That is not good news but if retirements on the table than enjoy the hell outta that!!
I ran without a heater in -30 Calgary weather for about 2 years and never once had an issue. Or at least not one that I noticed...
Hey Richard,
Sorry to hear about your "forced" retirement. Just means you'll have lots more time to keep the D2 running. :toothy7:
Regards,
Regards,
rgallant
Well solid days work today, I will have more of a write up but here is the end of day pic. Pretty sure I messed up the firing rider so that needs to be reviewed in the AM.
Got tired of whacking my knuckles on the lifting eye so it is a nice "see I am right here red" now
https://i.imgur.com/PmPZKu9.jpg
rgallant
Long day today not much progress a lot of wiring to re-wrap.
Upper Intake manifold on and off 3 times and 1 more time to go
- Missed SAI pipes of all things
Dropped a nut - it lodged in a bad place
Dropped and lost an coil bracket bolt
Noticed I had not checked off verify the valve covers are tight on my check list
