Disco 1 door latch issue.
Amadreas
Wet and Wild
#1 Post by Amadreas » Sat Feb 22, 2020 11:33 am
Hello all,
On my Disco 1 after unlocking all the doors, door lock plungers pop up normally, but on the rear driver side when I go to unlatch the door the plunger pops down thereby the door won’t unlatch to open. I have to pull the plunger up fully to open and stays that way until the next lock/ unlock cycle. On the tailgate the plunger pops up but pops down (mechanical) when trying to unlatch the door. I have to insert my key and hold the lock in the unlock position in order to open the tailgate each time.
Is this situation a latch adjustment or latch spring replacement?
landcrabmechanic
Hot Manifold
Re: Disco 1 door latch issue.
#2 Post by landcrabmechanic » Sat Feb 22, 2020 12:06 pm
It is a small little circular spring. I have a few extras in east van if you need.
Amadreas
Wet and Wild
#3 Post by Amadreas » Sat Feb 22, 2020 12:09 pm
landcrabmechanic wrote:It is a small little circular spring. I have a few extras in east van if you need.
I do need them then. I’m in Vancouver near city hall. I could pick them up from you. Price? PM me for contact info.
Amadreas
Wet and Wild
#4 Post by Amadreas » Sat Feb 22, 2020 12:17 pm
Sorry I jumped the gun and PM you my contact details.
Amadreas
Wet and Wild
#5 Post by Amadreas » Mon Feb 24, 2020 7:05 am
Received some new latch springs. Will start the arduous process of replacing the springs. Thanks again.
rayhyland
Drip Dry
#6 Post by rayhyland » Sat Mar 21, 2020 9:37 am
Amadreas wrote:Received some new latch springs. Will start the arduous process of replacing the springs. Thanks again.
Would you mind documenting the process with photos?
Amadreas
Wet and Wild
#7 Post by Amadreas » Tue Mar 24, 2020 9:15 pm
I will fully document the procedure once I get time to. Still working as I’m considered an essential employee.
