Mystery switch & wire
RamblerRob
Green Laner
#1 Post by RamblerRob » Sun Jul 19, 2020 10:18 am
Hey guys.
Need help figuring out what this switch and wire might be for. Truck has been heavily rewired.
Its a simple on off switch on the lower right dash of an s2a. Probably not standard.
It gets power only with key in start position. Has a long wire that can reach the front of engine bay or back to about mid truck.
Truck was running a naturally aspirated diesel engine previously.
Any thoughts on what it might be for?
BjornErickson
Newbie
Re: Mystery switch & wire
#2 Post by BjornErickson » Sun Jul 19, 2020 10:21 am
fuel pump?
RamblerRob
Green Laner
#3 Post by RamblerRob » Sun Jul 19, 2020 10:29 am
But its only live when the key is in the momentary start position not the run position. Not sure if fuel pump would make sense
RamblerRob
Green Laner
#4 Post by RamblerRob » Sun Jul 19, 2020 10:34 am
Also. In addition to the key start position to crank there is a separate crank switch (i assume) in center dash. So maybe someting to do with glow plugs?
Greasy Fingers
#5 Post by Rob » Sun Jul 19, 2020 12:44 pm
Lots of possibilities... heater motor, electric radiator fan, power supply to a relay for auxiliary lights, interior lights, back-up lights (examples of what my series rovers have had)...
RamblerRob
Green Laner
#6 Post by RamblerRob » Sun Jul 19, 2020 1:07 pm
Do any of those make sense to be live only on key start (not run start, just start)
RamblerRob
Green Laner
#7 Post by RamblerRob » Sun Jul 19, 2020 1:11 pm
Must have sonething to do with the ignition circuit. Wires are on 12ga... Maybe 14...
Might not matter as i have to redo the ignition circuit anyway
Greasy Fingers
#8 Post by Rob » Sun Jul 19, 2020 4:13 pm
Whoops, misread the post regarding the "start" position. :oops:
Now I'm thinking it is a low-tech anti-theft device, power circuit to the starter solenoid to prevent someone from starting it without flicking the right switch?
#9 Post by red90 » Sun Jul 19, 2020 4:57 pm
If it is powered in a position between on and start it is for glow plugs.
#10 Post by ANDYD » Sun Jul 19, 2020 10:00 pm
I've seen a wire like that for an exciter circuit to a (non standard) alternator. Some after market alternators need a initial exciter voltage to get them kick started. :dontknow:
RamblerRob
Green Laner
#11 Post by RamblerRob » Sun Jul 19, 2020 10:21 pm
My first thought was glow plugs but never dealt with diesel before. I think the ignition switch is from a petrol rrc so that might explain the muckery.
Now that i know i can put my mind to rest :)
