In need of trailer wire
Forum rules
KristenC
- Rookie
Hi everyone! I'm looking for a 7 pin connector wire for my 1998 range rover. The part number is ymz500470, land rover of coarse doesn't sell it anymore so I'm hoping to find a used one on the island. If anyone knows about one around please let me know!
harv
- Maxi Drive
Re: In need of trailer wire
I have a Canadian Tire 7 pin connector on my '97 P38.
harv
- Maxi Drive
Do you already have the converter (for brake and signal on same bulb)? If so, just buy the 7 pin connector from Cdn Tire, Lordco, Napa etc and wire it in. If you don't yet have the converter you'll need to get one and wire it in as well. I ordered the converter from Atlantic British, which was plug and play.
RobinS
- Over Inflated
Those converters can be sourced locally also. We use them in the trucking industry so Japanese trucks like Isuzu and Fuso can pull North American built trailers with the lamps , as Harv said " brake and signal on same bulb ".
harv
- Maxi Drive
Quite right. In my D2 and S2A I have Cdn Tire converters wired in. For the P38 I ordered the plug in version.
