Where does this part go?
Arcades
- Captain Crunch
So this part fell off my truck yesterday... Can anyone tell me where it belongs?
Re: Where does this part go?
Why in my garage, of course! 🤗
- Horn Blower
You don't want that, it will not run worth a dam on diesel ;)
Arcades
- Captain Crunch
My thoughts exactly!
Arcades
- Captain Crunch
Well now I don't have to worry about fuel at all anymore
Arcades
- Captain Crunch
But look at my lift now... To think all I needed to do was take out the brick.
Hey Mark,
Finally time for that Electric Conversion? Where will you put the 18 batteries? :wink:
Arcades
- Captain Crunch
I just want to pay back everything that I got from you guys.... mainly the diesel exhaust fumes!
acg
Mark,
Are you planning on replacing with V8 with something else? Or simply re-building the existing engine?
Either ways, good luck with the project. Looking forward to seeing you at one of our runs when the weather gets warmer.
Arcades
- Captain Crunch
This is going in....
It's a om606 turbo, a 6l90e transmission and a Ashcroft special transfercase
Tony4921
Nice mod. Where did you get the sump for the 606?
Arcades
- Captain Crunch
I met this super nice guy online that had done this conversion more than once (they are the goto non OEM swap in Europe). I ended up shipping all my parts to his place and then he boxed them up and sent them here in a single shipment. Saved a ton of shipping. Also he had great advice.
Arcades
- Captain Crunch
It's from an om648
paulg_d130
- Little Wheel
keenly watching this so bring on the detail!
im toying with the idea of a om648 swap but still in the dreaming stage.
what did your get in your tcase? did you change the high range gears? add the ATB
Arcades
- Captain Crunch
It’s from Ashcroft. I HDed everything I could.. went to a higher gear set and the atb.
Arcades
- Captain Crunch
I figured that with all the torque from the new engine and the fact that I’m running 4.43 diffs I could use a higher gear.
Arcades
- Captain Crunch
In the hole!
Mark - where are you doing, or getting the work done?
Arcades
- Captain Crunch
It's being done at big country customs in Abbotsford. They also made my rear bumper for me amount many other things. They don't say no there.
Arcades
- Captain Crunch
Just a few shots of the progress... should be running in the next few days...
- (186.53 KiB) Downloaded 433 times
- (204.47 KiB) Downloaded 438 times
- (243.02 KiB) Downloaded 437 times
- (203.79 KiB) Downloaded 430 times
Arcades
- Captain Crunch
Intercooler pipes and exhaust
- (149.39 KiB) Downloaded 430 times
- (173.16 KiB) Downloaded 436 times
Sweet! Looking forward to seeing and hearing it. 👍👍
Arcades
- Captain Crunch
Me too... me too
Arcades
- Captain Crunch
The engine is now running... I would post a video but it's too large 😢
Arcades
- Captain Crunch
Had an issue with the linkage for my transfercase. I had too move it back because of the longer transmission. I didn't want to cut more holes in the floor and cut up my automatic console. I found the solution by following what the English guys are doing when they swap Cummins in... Often they put in larger transmissions including alisons! They go with a pneumatic system.. maybe an alternative for the disco guys who want to put CDL in....
