#176 Post by ANDYD » Wed Feb 24, 2021 11:42 pm
Hi Robin,
The vent seals you did look great, I will likely go the same route when I get to mine.
Time for an update, The wiring continues (new wiring loom) running the cables through the bulkhead to the dash panel as well as inside the chassis to the rear cross member for the rear lights. The single rear lights are the side light, brake light and Indicator all in one, so that will take require some further study of the WS manual wiring diagram to figure that out.
I connected up the dash panel which I found fairly straight forward. I am converting mine to Negative Earth (it was originally Negative Earth). Also installing a Alternator in place of the old dynamo.
(169.97 KiB) Downloaded 344 times
(182.13 KiB) Downloaded 345 times
(175.86 KiB) Downloaded 346 times
#177 Post by ANDYD » Wed Feb 24, 2021 11:51 pm
I was able to get replacement S1 engine breathers (thanks for Andre) my engine was missing them for some reason. They are different than the later Series engine breathers.
They had been "gentle" used for around 60 yrs ... so needed some refurbishment.
(127.28 KiB) Downloaded 344 times
(164.74 KiB) Downloaded 342 times
#178 Post by ANDYD » Thu Feb 25, 2021 12:06 am
Back to completing the Brakes. I had ordered a Master Cylinder Internal rebuild kit, a new Brake Fluid Reservoir and the connecting pipe from Three Brothers Parts. The brake pipe route is a bit strange because the Reservoir is under the passenger seat and the Master Cylinder is under the drivers seat (on LHD).
Once it was all together, I filled the system with Dot 3 brake fluid and starting bleeding with very limited success (and a few swear words). I then borrowed a "Power Bleeder kit" (thanks Martin) and had the pedal nice and hard in about 30 mins. I definitely recommend using a Power Bleeder, much easier and simple to use.
On the back of the brake pedal there is a little triangle shaped plate with some holes in it which allows a return spring to be hooked on. Mine was missing so luckily I was able to make one fairly quickly.
(83.93 KiB) Downloaded 344 times
(173.33 KiB) Downloaded 346 times
(188.5 KiB) Downloaded 340 times
#179 Post by ANDYD » Thu Feb 25, 2021 12:35 am
I now believe its time to dry fit all the body panels. I want to fit everything to confirm the fit, repair any extra holes, straighten out some panels, see what's missing etc
I also want to take it for a good test drive before doing the final paint job. Its just nuts and bolts and I have never seen this vehicle complete before (as I purchased it in parts) ... so here goes nothing
I started with the rear tub, then the seat base and lids. The floor panel was next followed by the hood (bonnet) & front wings (fenders).
(205.09 KiB) Downloaded 344 times
(203.65 KiB) Downloaded 341 times
(158.64 KiB) Downloaded 341 times
(155.77 KiB) Downloaded 341 times
(195.32 KiB) Downloaded 342 times
sailourboy
Cross Member
#180 Post by sailourboy » Thu Feb 25, 2021 8:28 am
Hey Andy, looking good!! Feels more like a sense of accomplishment once the externals are put on I bet?
Ted
rayhyland
Drip Dry
#181 Post by rayhyland » Thu Feb 25, 2021 10:28 am
Looks fantastic Andy, well done!
rayhyland
Drip Dry
#182 Post by rayhyland » Wed Jun 09, 2021 6:27 am
Any updates Andy?
#183 Post by ANDYD » Fri Jun 11, 2021 12:34 am
Hi Ray / Ted,
Yes, I have had a few fun road trails along the river just to "bed in" the new pistons rings after the engine rebuild also to tweak the carb and do some final adjustments. So far so good, she runs like a new vehicle! She's very happy to be back together again after 15 plus years in pieces.
I'm falling for the old patina paint so not sure if or when I will get around to painting the body panels :?
But for now, back on the road and loving it :bounce:
(237.87 KiB) Downloaded 272 times
(319.88 KiB) Downloaded 276 times
#184 Post by ANDYD » Fri Jun 11, 2021 12:44 am
Back on the road again ...... first "road trials" after 4 year rebuild 8)
(252.1 KiB) Downloaded 269 times
(362.47 KiB) Downloaded 270 times
rayhyland
Drip Dry
#185 Post by rayhyland » Mon Jun 14, 2021 9:00 pm
Fantastic!
oldgravy
Captain Crunch
#186 Post by oldgravy » Tue Jun 15, 2021 10:10 am
Congratulations!
#187 Post by bsa_m21 » Tue Jun 15, 2021 10:18 am
Congrats!
