D1 fan clutch
Forum rules
landcrabmechanic
Hot Manifold
D1 fan clutch
#1 Post by landcrabmechanic » Wed Aug 04, 2021 6:50 pm
Anyone in Kelowna area have a disco 1 fan clutch for sale? I believe mine failed in freewheel mode today as I almost overheated on the coq today.
Scott
604 763 2999
rgallant
Cylinder bore
Re: D1 fan clutch
#2 Post by rgallant » Wed Aug 04, 2021 9:35 pm
Hayden makes a drop in, that works on D2. Hayden 2781, 2791 or 2991 regular /heavy /severe duty cycles. I believe they also work on a D1.
You should be able to get one at Lordco or similar - check Rockauto for part numbers
Re: D1 fan clutch
#3 Post by bsa_m21 » Thu Aug 05, 2021 9:23 am
More likely than the fan clutch, if its still the original rad, it’s time to replace or recore your radiator. I did this in my D1 and she stopped overheating right away. Best $$ I’ve spent on her.
landcrabmechanic
Hot Manifold
Re: D1 fan clutch
#4 Post by landcrabmechanic » Thu Aug 05, 2021 7:33 pm
Thanks rgallant, I will look those up.
Bsa_m21 my rad is good. I do know the fan clutch has failed.
I will look for a Hayden.
Scott
landcrabmechanic
Hot Manifold
Re: D1 fan clutch
#5 Post by landcrabmechanic » Sat Aug 07, 2021 9:39 am
Problem with the Hayden fan clutches is they are for a Chevy astro van. I would have to drill out my fan mounting bolt holes. Not into doing that.
