Does anyone know this bearing part number?
deanc5
Wing Nut
#1 Post by deanc5 » Wed Aug 11, 2021 12:36 pm
Hi, I have finally found a source for the PTO covers I need to remove the PTO from my series 2a transfer case. There is a needle bearing in the rear cover that needs to be replaced. I have spent about an hour online trying to get a part number and to perhaps obtain a cross-referenced bearing locally. I have pointed out the bearing in the attached pic. If you know of a part number or source for these please let me know.
Dean
(34.29 KiB) Downloaded 98 times
Re: Does anyone know this bearing part number?
#2 Post by mepham55 » Wed Aug 11, 2021 2:37 pm
That’s the rear mainshaft end bearing part number 217478
https://www.johncraddockltd.co.uk/21747 ... -bush.html
deanc5
Wing Nut
#3 Post by deanc5 » Sat Aug 14, 2021 12:45 pm
Thanks Matt, I found a source in BC. So that's one more detail taken care of with help from the roverlanders group. : )
