TD5 exhaust manifold skimming
philchan1974
Over Inflated
#1 Post by philchan1974 » Thu Sep 09, 2021 9:01 pm
Any suggestions where to get this done and/or find a reman one already done?
Thanks.
landcrabmechanic
Hot Manifold
Re: TD5 exhaust manifold skimming
#2 Post by landcrabmechanic » Thu Sep 09, 2021 9:07 pm
If you take the manifold to any competent machine shop, they will be able to skim it for you.
paulg_d130
Little Wheel
#3 Post by paulg_d130 » Mon Oct 04, 2021 2:41 pm
i did mine at home on my large belt sander and just used a long stainless steel straight edge (ruler) to check it as I went. use 80 and 120grit belts and it worked quite well.
