Series/Disco Hybrid Build
webmaster
Half Shaft
Re: Series/Disco Hybrid Build
#101 Post by webmaster » Thu Aug 18, 2022 2:59 pm
Ok, I’ve likely lost 10-20 lbs in sweat over the last few days as it’s hot enough to cook eggs in the garage, but the bulkhead and steering are now mounted and the brakes are plumbed.
(376.03 KiB) Downloaded 320 times
(372.18 KiB) Downloaded 322 times
(336.91 KiB) Downloaded 325 times
(432.85 KiB) Downloaded 334 times
(301.66 KiB) Downloaded 328 times
(301.28 KiB) Downloaded 333 times
#102 Post by bsa_m21 » Fri Aug 26, 2022 9:09 am
Brakes are done and bled. Accelerator cable made and installed. Wiper motor and wiper assembly in. Time to start fitting the fuel tanks then i’ll finish the wiring. Hopefully I haven’t messed up the GEMS wiring. 😳
(386.91 KiB) Downloaded 299 times
(191.39 KiB) Downloaded 294 times
(253.12 KiB) Downloaded 300 times
Making progress! Yay! 🤗
#103 Post by swamijake » Sat Aug 27, 2022 8:15 am
Functioning wipers? Luxurious!
#104 Post by ANDYD » Thu Sep 08, 2022 9:52 pm
Looking good Marty, wont be long until the road test is here! keep it going :bounce:
#105 Post by bsa_m21 » Sat Sep 10, 2022 8:59 pm
Been making a fair bit of progress the past 2 weeks.
Got he seat box painted and mounted.
(380.83 KiB) Downloaded 245 times
Started figuring out the dual battery wiring.
(232.97 KiB) Downloaded 246 times
Re-welded the custom exhaust the previous owner mickey-moused. Every weld was porous and leaked. The arch over the rear axle was in the wrong place and needed to be moved back 2”, and I added a quiet resonator as well. My version is ugly, but she don’t leak or hit anything anymore.
(415.14 KiB) Downloaded 250 times
Then I insulated the bulkhead.
(435.83 KiB) Downloaded 245 times
(425.38 KiB) Downloaded 248 times
Even did the brake tower. 🤗
(326.81 KiB) Downloaded 246 times
Then I did the heater unit and got started figuring out where and how to mount the various bits needed to make her run. The GEMS cpu is now mounted on the bulkhead, behind the engine. I still have to make an insulated cover for it.
(434.12 KiB) Downloaded 249 times
All in all I’m quite pleased how she is coming together.
#106 Post by bsa_m21 » Sat Sep 10, 2022 9:25 pm
Ah yes, two steps forward and one back…. My daily driver, a ‘96 Disco 1, decided to start consuming copious amounts of coolant a few weeks back. I had most of the bits to do the head gaskets, but I’ve been waiting on a new oil pump before I pulled it apart. Pump arrived yesterday so today I began the disassembly. Oy. Dirty and greasy. Yuck. Once she cooled off, it took the rest of the day to get it down to bare heads. They’ll come off in the morning.
I’m not sure if this motor has ever been apart before as it has relatively low mileage (kilometerage?). Regardless, I don’t know it’s history before I bought it a few years ago. I’ve always done regular oil changes, Castrol 20/50, so expected the insides not to be too bad. Alas it was not to be. This is what the insides of the rocker covers look like:
(389.19 KiB) Downloaded 242 times
The brown guck in the passenger side cover is scary. Yuck.
And this is inside the motor….
(355.9 KiB) Downloaded 245 times
Surprisingly the cam looks ok at first glance. Once I’ve got the heads of I’ll know more.
Guess I’ll pull the oil pan while I’m at it and flush the entire block with brake cleaner to try to clear out as much of the crud as I can. Always something to slow down my series-hybrid build…. 😳😵‍💫
#107 Post by bsa_m21 » Sun Sep 11, 2022 5:51 pm
Well it took all day, a trip to Princess Auto and 3 to Cdn Tire, but the heads are off. Amazing what frozen bolts you can undo with a 40” breaker bar! 🤗
(326.56 KiB) Downloaded 226 times
They don’t look bad at all.
Actually the cylinders also look good. No ring ridge at all. Cylinder 5 looks like it may be washed, but the matching head section isn’t, so I’m not sure about that. All sleeves are flush with the top of the block, so I may be lucky with this motor.
(384.37 KiB) Downloaded 233 times
(394.69 KiB) Downloaded 229 times
M
#108 Post by bsa_m21 » Wed Sep 14, 2022 8:17 pm
Well my truck challenged me ….. and it won. It started losing coolant a few weeks ago and kept getting worse, so Sunday i took it apart. I thought I could do the head gaskets, lifters, oil pump and timing chain in two days. That is, until I opened it up and saw the crud build up. Ok, an extra day for cleaning and degreasing the parts and inside of the motor, so three days for sure. Yah, right…. Well today was day four and I ran out of steam with the exhaust to re-mount and fluids to fill. At least it will be on the road tomorrow. Sigh. 😵‍💫
M
#109 Post by bsa_m21 » Mon Sep 19, 2022 9:44 pm
Well the Disco is back on the road. Engine sparkling clean inside. Lifters, oil pump, head gaskets, valley pan and injectors replaced. I pulled the oil pan and checked the main and rod bearings while I was at it. All good. New rad hoses. Fresh oil and coolant. Running like new again. Now back to work on the Disco/Series hybrid build. :bounce:
#110 Post by bsa_m21 » Sat Oct 01, 2022 4:54 pm
(459.27 KiB) Downloaded 107 times
Damn. I hate modern (well 1990’s) wiring. Specifically GEMS wiring. For the past several weeks I’ve been trying to work out what I can and shouldn’t delete. I sure hope I got it right now. Still need to hook up the dash wiring before I can’t really test it out. 🤞 I mounted the GEMS cpu on the bulkhead, so I’ll have to make up a cover to block some heat and the weather. That’s easy though.
(482.11 KiB) Downloaded 104 times
#111 Post by bsa_m21 » Sat Oct 29, 2022 8:52 pm
Made a fair bit of progress the past few weeks. Finally sorted out wiring of the GEMS/Alarm unit and am able to connect to the cpu via the ODBII connection, wired up the seat box for dual batteries, painted and wired up the dash. Only took several dozen times of tearing the harness apart, 2nd guessing myself, to sort out “did I do that right?” type issues. Even repaired and sealed the Series 2 side tank. Going to use it until I get a replacement for the plastic Disco tank built. Then it will be used as an auxiliary tank feeding to the rear tank when I turn on it’s pump.
(423.67 KiB) Downloaded 77 times
(334.86 KiB) Downloaded 76 times
(331.1 KiB) Downloaded 81 times
(233.84 KiB) Downloaded 76 times
(211.36 KiB) Downloaded 68 times
(331.98 KiB) Downloaded 77 times
(214.16 KiB) Downloaded 75 times
(225.21 KiB) Downloaded 74 times
(195.28 KiB) Downloaded 81 times
(483.99 KiB) Downloaded 73 times
(493.21 KiB) Downloaded 74 times
Will mount the tank and pumps this week and then 🤞 fill the fluids and try starting her! :bounce:
Oh, and I bought a black 05 LR3 HSE last week as well. Glutton for punishment, I guess…😎
#112 Post by swamijake » Thu Dec 21, 2023 9:06 am
Looking good!
#113 Post by ANDYD » Wed Dec 27, 2023 7:51 pm
huuummmm the BIG RED switch is very intriguing ..... ejector seat maybe? :smilebox:
