Might be of use to someone…
https://www.canadiantire.ca/en/pdp/shel ... 9180p.html
5 US Gallons (18.9L) for $83.99 ($97.88 all-in).
Most places want $50-$60 for 5 litres.
Good price on Shell Rotella T5 15W40 at Canadian Tire…
withabix
harv
- Maxi Drive
Re: Good price on Shell Rotella T5 15W40 at Canadian Tire…
Thanks for that heads up. I should check the price on the 5W40. Winters get a little colder here in the Okanagan.
I always used Shell Rotella T4 in the past, now you cant find it anywhere? :roll: Any location tips?
The Shell Rotella T5 is Synthetic, anyone already using the T5 in their diesel engines? Thoughts/comments on the T5 in a TDI engine?
withabix
Princess Auto keeps Rotella T4.ANDYD wrote: Tue Sep 13, 2022 9:32 am I always used Shell Rotella T4 in the past, now you cant find it anywhere? :roll: Any location tips?
I was using T4 - I changed back to T5 from T4 to see if it made any difference. Seems to be less smokey so far, but I haven't done any longer trips yet. Waiting to see if it is less drippy....
Semi-synthetic and Dinosaur 15W40 both seem to be fine in a 300TDI according to the internet.
We probably change our oil so often that it makes no difference what you use!
harv
- Maxi Drive
Isn’t T5 Semi-synthetic and T6 full synthetic?
withabix
