1956 109 Partial Restore
NWOnt_1956
- Learner Driver
Hi, thanks for letting me join. I'm not in BC but I used to live in Prince George so have a connection with your great province. I recently picked up a 56 109 that has been in my family since early 1970's. It has been sitting since 1990 and not driven.
I brought it home to Thunder Bay and I'm starting to make a list of repairs to get it back on the road. Surprisingly the frame ans bulkhead look to be in good shape some surface rust but seems solid. I think this is mostly stock and I do not think there are many miles on it as it was only used for hunting while my family owned it.
Thinking of a partial restore and getting it back on the road. I am going to pull it into the garage for the winter and see how far I can get with it. The engine was running before it was parked but considering taking it out and going through it, new valves, rings, gaskets etc.
Will need brakes, suspension, replace exhaust manifold, and lots of little items.
Though I would share and might ask some questions along the way.
Keith
Keith
- (478.15 KiB) Downloaded 1009 times
- (526.18 KiB) Downloaded 1004 times
- (335.1 KiB) Downloaded 1004 times
- (418.98 KiB) Downloaded 1004 times
- (338.5 KiB) Downloaded 1005 times
jacobko
- Crank Case
Re: 1956 109 Partial Restore
Awesome! If you need guidance, feel free ask me questions and to check out my ongoing build in the projects section titled "1958 Series 1 88" "red&red"". Also ANDYD has posted his full rebuild titled "1956 Series One Rebuild Project" which has helped me as I go along with my build.
NWOnt_1956
- Learner Driver
Thanks, I had a read through your posts and the other one you mentioned. Lots of great information that will surely help me, thanks for posting your progress. I have been making a list of obvious things I will need and have started to find where I can source them. Seems like a few options but looks like most are out of the country.
Looking good.
FYI - Another great resource, and closer to you, is the Ottawa Valley LR Club (OVLR.ORG).
NWOnt_1956
- Learner Driver
Hi, after getting some other projects completed moved the LR into the garage. A few nights of work and starting to remove some body panels. Starting to make a shopping list of what to replace.
- (364.2 KiB) Downloaded 923 times
- (299.88 KiB) Downloaded 925 times
- (429.52 KiB) Downloaded 925 times
- (447.4 KiB) Downloaded 925 times
- (324.04 KiB) Downloaded 921 times
Nice, that's a great start!
I see lots of history unfolding, lots of different paint colours, it looks like its had an exciting life!
Have fun, what a great winter project 8) (if your garage is heated)
NWOnt_1956
- Learner Driver
Making some progress on the tear down. Next will open up engine and see what it looks like. Ordered parts to get suspension, brakes and steering back in shape. Frame looks in great shape. Will replace foot wells as they are starting to rust and a few holes appearing. Hope to paint the frame once I start working on suspension. So far so good.
- (353.96 KiB) Downloaded 867 times
- (384.12 KiB) Downloaded 866 times
- (403.53 KiB) Downloaded 872 times
- (392.81 KiB) Downloaded 868 times
NWOnt_1956
- Learner Driver
Winter had arrived, so more time to spend in the garage.. Making some progress, engine is out, and have it down to the block and crank. I found a tag on the engine, looks like it was rebuilt at some point and bored .020 over. Cylinders still have some hatch marks so that is good news. Exhaust valves are a a tan color so not sure if they are original or have been replaced? Camshaft looks like it has some wear but not sure how much is too much. Parts are starting to show up for the suspension, brakes,steering and front end. Hoping to get front pulley off engine today and inspect the cam. Still debating if I need to remove crank and pistons or just clean up cylinder where carbon has built up.
- (135.91 KiB) Downloaded 835 times
- (215.28 KiB) Downloaded 840 times
- (170.42 KiB) Downloaded 830 times
- (143.15 KiB) Downloaded 828 times
- (138.02 KiB) Downloaded 829 times
StuartC
- Wing Nut
Being that far in to the engine I think I would seriously consider pulling the crank, check the bearings, inspect the pistons and rings......never know if you have a spun bearing or a piston/ring issue......until you look.....
Given the apparent condition of the piston crowns, I expect that at a minimum you’ll need a new set of rings. 🧐
NWOnt_1956
- Learner Driver
I decided to take it all apart. Got the timing gears off today and worked on the head. The valves were very stiff I had to tap them out as there was lots of carbon build up. Also cleaned the pistons and cylinder walls to assess. All looks good now but will know better when I get the pistons out. I hope to get the camshaft out tomorrow.
RobinS
- Over Inflated
Hi Keith , just a word about the 2 litre camshaft. they are a weak point in the engine along with the tappets. I had mine reground back to factory spec. Colt Camshafts here in Aldergrove B.C. have the grinding profile for these cams although you could most likely find someone near to you that can do them also. When you put it back together , it's highly recommended to use a zinc additive in your oil to protect the flat tappets and cam. Cheers Robin
NWOnt_1956
- Learner Driver
Hi Robin, thanks for the info, i just finished the total teardown this weekend and the cam and cam followers are worn down. I got pricing on a new cam and followers but yikes expensive from the UK. I was going to look into getting it re-ground but I wasn't sure this was possible with this ole gal. Are they able to rebuild the surface on the followers (tappets) as well?
Cheers Keith
Cheers Keith
RobinS
- Over Inflated
I phoned Colt Cams for you yesterday and the price to bring your camshaft back to new is $275.00 but unfortunately he can't do the followers. I sent you a PM
Tony4921
I have several rocker levers, there are left, right, intake and exhaust I think. Which ones do you need. I also have 2 or 3 cams, but they are worn as usual. Post some pics and I will see if I have any better parts for you.
NWOnt_1956
- Learner Driver
Appreciate the info and help. Attached are some photos of engine component's. Trying to sort out what to order and what to fix.. Depends how much my banker will allow. Have lots to work on over Xmas, want to get the final parts off and start to work on the front end. The cam followers almost all look like the ones posted. And most cam lobes show some wear.
- (82.73 KiB) Downloaded 682 times
- (116.24 KiB) Downloaded 680 times
- (113.37 KiB) Downloaded 678 times
- (146.57 KiB) Downloaded 684 times
- (83.24 KiB) Downloaded 680 times
NWOnt_1956
- Learner Driver
More photos
- (149.76 KiB) Downloaded 680 times
- (53.32 KiB) Downloaded 682 times
- (101.48 KiB) Downloaded 681 times
- (83.24 KiB) Downloaded 682 times
- (46.57 KiB) Downloaded 681 times
Tony4921
That cam will regrind no problem, the guy Robin recommended is good. Craddocks sell the exhaust rochers 15-18 GBP each. I would put in a whole new set. The ones I have are worn also.
NWOnt_1956
- Learner Driver
Thanks for all the info on the engine. I decided to get a new cam and the aftermarket rockers. Also ordered a new manifold , crank bearings, exhaust valves, conn rod bearings, and a few odds and ends. All the parts arrived yesterday. While waiting for the parts I pulled the front Diff and springs. Got the old chassis bushings out, that was fun. Found the front diff casing was damaged many moons ago and welded up. The inside casing was rubbing a bit on the crown gear. Not a big issue but going to get that fixed up. My father was visiting for a week at Xmas so we teamed up and worked a few days on the frame and foot wells. LOTS of cleaning of parts and frame so I can paint things up, soon I hope.
My father owned it for the last 30 years so he was keen to see it being fixed up.
- (142.47 KiB) Downloaded 639 times
- (109.64 KiB) Downloaded 636 times
- (89.15 KiB) Downloaded 639 times
- (58.03 KiB) Downloaded 642 times
StuartC
- Wing Nut
There are some pretty good restoration YouTube videos available from Britannica Restorations in PQ.....the website is britrest.com
In-depth series on 2.25l petrol rebuilds and bulkhead restorations.....plus ++
A good resource.
A good resource.
NWOnt_1956
- Learner Driver
I have a question about the serial numbers I’m hoping someone can shed some light on. I have been trying to find some info on this but cannot seems to search it up. The serial number on the bulkhead tag of my LR is 1246002515, i had a look for the number on the chassis rear spring left side and it is 124602742 I thought these 2 numbers would be matching for an original vehicle, but maybe not.
bfein1075
- Learner Driver
Serial should be on the passenger side front right in front of spring hanger.
It should match the vin plate.
tygre
- Learner Driver
On a 1956 109" the serial number is on the drivers rear spring hanger, not the front passenger.
The number on the bulkhead plate should be the same if it is originally from the same vehicle.
The number you mentioned on the bulkhead tag has one too many numbers.
I have 124602447.
I have 124602447.
NWOnt_1956
- Learner Driver
Hi, a bit of a clarification, my father told me the VIN number on the old registration/insurance card matched the bulkhead tag (it is not close the numbers after 1246 are way off???). I had removed it and stored it away for the rebuild. I pulled it out to double check (should have done that first) The Chassis number on the rear just above the left spring does match the bulkhead number although someone added 2 numbers to the bulkhead tag (stamped an 03 behind it?).
The problem now lies in the registration card from 1990's does not match the Vin number of the vehicle.
The good news is the bulkhead and chassis match which is what I had suspected as the vehicle has been in the family since 1970's.
NWOnt_1956
- Learner Driver
Have been spending a few hours in the garage over the last couple weeks. Most of the work has been on the engine. Cleaned the block and cleaned the block.. Paint went on very well. Worked on the head, cleaned it up and flat sanded the face. Cut the valve seats and lapped all valves. Ordered new exhaust valves so got those paired with the block. Honed the cylinders they look pretty good now. Spent time inspecting the new conn rod bearings and setting the clearances. Switched to crank bearings and all seems in order. Installed the new rings on pistons. So ready to start reassembly. Has been fun and lost of elbow grease cleaning parts.
- (117.92 KiB) Downloaded 571 times
- (119.89 KiB) Downloaded 570 times
- (93 KiB) Downloaded 573 times
- (75.81 KiB) Downloaded 571 times
