Just cleaning out a few things..
Exmoor trim door pocket panels( 1 pair) new never used.. should fit any sliding window rover. charcoal grey $70
2 New genuine never fitted LR FRC 8393 prop shafts, gkn u joints ..( Defender 90. 300/td5 ) for rear. $65 Each
Speed in miles missing rubber button, but works perfectly fine..$10
Can deliver from Nanaimo to Vic.
Cheers.
Henryk.
Prop shaft , speedo and door pocket panels
Forum rules
Bargrip
- Junior Craftsman
- (85.94 KiB) Downloaded 205 times
- (78.97 KiB) Downloaded 204 times
- (58.36 KiB) Downloaded 204 times
- (74.98 KiB) Downloaded 205 times
- (100.81 KiB) Downloaded 204 times
StuartC
- Wing Nut
Re: Prop shaft , speedo and door pocket panels
Hi Henryk
I'll take the door pocket panels please.
I'm in Courtenay.
Stuart
I'm in Courtenay.
Stuart
Bargrip
- Junior Craftsman
Ok, Stuart
They are yours..
I might even be able to meet you up there..
Just have to check my work schedule
They are yours..
StuartC
- Wing Nut
Thank-you
Well that would be a possibility.....you can give me some moral support on the restoration to this point on the '59.
I'll PM you re payment options.
Stu
Stu
