2.5 NA to 300tdi conversion
ryancr500
Tomb Raider
#1 Post by ryancr500 » Tue Oct 30, 2018 8:57 pm
I"m looking for a little extra power out of my 87 110 exmod 2.5 NA. Does anyone have some words of wisdom regarding a 2.5 NA Diesel to 300 tdi diesel conversion? I don't have a motor yet but I'm ready for the challenge.
Re: 2.5 NA to 300tdi conversion
#2 Post by swamijake » Wed Oct 31, 2018 12:51 pm
I did it. It's not too bad. I stuck with the lt77. If I was doing it again I'd go for the r380 as getting the rear oil seal to work with the 2.5 back plate was a bit tricky.
Don't use the 2.5 fuel filter. It's a silly setup.
#3 Post by red90 » Wed Oct 31, 2018 1:11 pm
A Defender 200TDI is a much easier swap. It was designed to be a bolt in swap. Easily done in a day.
A 300TDI requires quite a few modifications and there are various routes to take.
In either case, I suggest getting the gearbox and transfer case that match the engine. It avoids issues with having poor gearing ratios and poor strength to match the TDI. also make sure you get ALL of the ancillary parts that came from the donor vehicle. Missing some of those items is what ends up creating a lot of cost and time.
ryancr500
Tomb Raider
#4 Post by ryancr500 » Thu Nov 01, 2018 7:56 am
Great tips,thanks for the advice
radio_05
Gently Used Condition
#5 Post by radio_05 » Wed Nov 14, 2018 11:31 am
I assume your 110 is LHD, correct? RHD 110 may make Discovery 200tdi recycling much simpler.
ryancr500
Tomb Raider
#6 Post by ryancr500 » Wed Nov 14, 2018 12:12 pm
I have a left hand drive 110,
Low-Range
Junior Craftsman
#7 Post by Low-Range » Thu Nov 07, 2019 11:31 am
Did the same job u r looking at. Really wasn’t that hard. Had to tap one hole on rear of motor, grind a little bell housing around starter. Bought kit from Ashcroft ...made it very easy. It included new engine mounts, new exhaust down pipe, and other little pieces. Spend the money and save the headaches. Also got remanufactured transmission and transfer case... they worked excellently and haven’t had any problems.
