Defender parts compatibility, Which Parts Fit?
ryancr500
- Tomb Raider
I recently purchased a 1991 defender 110 project vehicle. It's missing some electrical parts from the dashboard. I'm wondering if any other Land Rover parts would be compatible, from a different model or year. Parts for the defenders seem to be hard to come by. I'm mainly looking for gauge cluster, but I'm also missing the complete key barrel and wiring that plugs into it. Any help would be greatly appreciated
Ryan
Ryan
Re: Defender parts compatibility, Which Parts Fit?
It depends. Most of the dash stuff is the same from 84 to 2001. Defender parts are super easy to find and are usually very cheap. You just need to download a a parts catalogue and look up the part numbers or use an online catalogue.
For the gauge cluster, a Raptor binnacle is a better choice than a Land Rover one if you are buying new and aftermarket gauges are better and cheaper than original.
http://new.lrcat.com/
https://www.landroverweb.com/landrover/ ... catalogue/
landcrabmechanic
I have an ignition switch for a disco 1 you can have. I have a key for it as well.
ryancr500
- Tomb Raider
I could use the ignition switch!! Where can I pick up?
landcrabmechanic
I am in east van. I will be home most of the day tomorrow.
ryancr500
- Tomb Raider
Ok. Will call in morning
